Install EFI connection LSX PCM
Worked on the coil mounting solution today for a little while, one of these day's I am going to get some pics uploaded. Also will be eliminating the TCS module on the driver side valve cover, and doing the passenger side wire and fuel line relocation mod to clean up the engine bay some.
So expect a call tomorrow Mike!
I will never discourage anyone from reworking their own harness. However, I have seen my fair share of used LT1 engine harnesses and they're not always in very good condition. The newest LT1 harness is now about 12 years old. With many years of heat cycles, condensation, modifications, etc...it's no surprise that these original harnesses are showing some wear.
Sorry guys I haven't been updating this thread, just too much going on.
Again anyone with info or pics, post up.
Have been working on a room remodel and haven't had alot of time to work on it.
Did you use the DIY harness, or end up getting one from EFI?
I will try and get some pictures on the computer, have them all on the camera just trying to find some time... EFI Connection sells two different reluctors.
24x Reluctor for Single Row Timing Set
Fits both early SBC and LT1/LT4 with single row chain. Clears the LT1 timing cover crank seal area.
24x Relcutor for Single/Double Row Timing Set
Fits both early SBC and LT1/LT4 engines, but does not clear the crank seal area of the LT1 timing cover. An alternative is to cut the timing cover to extend the crank seal area forward just a bit. This will require a TIG welder and some skill.
A new billet aluminum LT1 timing cover is in the works to resolve this problem. Should be available by the end of this year.
