Finally! Im starting my build !
#46
With the 355 and LE2 heads and the LE 226/232 .565/.565 112 LSA cam and LE ported intake should i go with a 58 mm TB and should i bump up the injectors ? What size if so?
#48
I guess i should, he has answered so many already LOL now i need to order my main and rod bearings someone gave me the part # for the clivites but it wasn't for the harden ones can you help me out there ?
#53
Here is my list so far, most is ordered all except TB and the stall
1. LT1 95 355 Block
2. LE2 Heads
3. LE 226/232 .565/.565 112 LSA
4. Mahl Forged Pistons
5. Scat 6 Inch I-Beam Rods
6. CC Pro Mags 1.6 RR
7. Mr Gasket 5716 head gaskets
8. Trick Flow 21407100 pushrods
9. Trick Flow 30400623-8 guide plates
10. All ARP Hard ware
11. LE Ported Intake
12. Melling 155 Oil Pump
13. Clevite H Series Main Bearings
14. Clevite P Series Rod Bearings
15. Professional Prod. 69702 GM LT1 58 MM Throttle Body
16. Yank ss3600
17. Strange 3:73’s
18. GM LT1 timing Chain
19. Poly Motor Mounts
20. MSD 8.5 OTVC wires
21. 37# injectors
22. Walbro 255 Fuel Pump
Winning $10,000 3 weeks ago and $8,000 last Wed. on the Lotto PRICELESS ! !!!!!!! !!!
1. LT1 95 355 Block
2. LE2 Heads
16. Yank ss3600
17. Strange 3:73’s
21. 37# injectors
#54
1. LT1 95 355 Block
2. LE2 Heads
8. Trick Flow 21407100 hardend pushrods
16. Yank ss3600
17. Strange 3:73’s
1. LT1 95 355 Block
2. LE2 Heads
16. Yank ss3600
17. Strange 3:73’s
#59
I bought my Yank SS3600 from SpeedInc. Give larry@speedinc.com an email and he'll take care of you.
I LOVE my 3600... wish I would've gotten a 4000 though as they are really good for nitrous setups in case i'd what to do that in the future.
