Checking PVC on my 355
The heads are LE2s milled .030
all the pistons(forged Speed pro) are .010-.012 in the hole deck was cleaned up not milled
Im using MR G 5716 .026 head gaskets.
Cam Specs are 230/236 565/568 108 lsa.
What are you guys doing
Thanks!!!
Thanks!!!
2.) If you still want to check it, you can take apart one of the lifters you're planning on using and insert something in place of the plunger and reassemble it as a solid lifter. Don't forget to change it back when you're finished though!
Im 99.9% positive it will be fine, but I just would like to double check anyways. After I had the cam/ sprockets timing cover and everything back on and knew 100% it was all installed right when I was done. I pulled it all apart just to make sure. Sometimes I just think to much about stuff..
Ill see If I can find a stock set of lifters to convert. I think my buddy has a blown up LT1 sitting in his shop that I can steal some from.
I checked mine with clay just to be safe and there was plenty of clay.
I have:
The same Speed Pro Pistons
Heads milled .020"
Mr. Gasket .026" gaskets
Cam specs are 234/238 565"/.565" on a 112 LSA
We have VERY close setups so I would be bother to check
Anyone know what the stock PVC is?
Look on the bright side, what you're doing right now is what I was doing two weeks before the LTxshootout, so at least time is on your side
I can't wait to see how your car runs with the new shortblock
Mine hasn't been down the track since you and I ran the last pass at the ltxshootout, I haven't bothered since we're still faced with 3200'+ DA in KS right now
. It was just way too nasty out, then I discovered covered the broken rocker.I finished up the engine lastnight. Just some engine bay detailing and waitng on my Happy hooker to get it back in.
Problem is, like I said B4 im working everyday 10-8 untill next friday. So it could be a minute.
