Removing cylinder heads
So, I have unbolted the right head and tomorrow the left will get unbolted. However, there seems to be some sort of pipe around the back, connecting both cylinder heads together. What is this pipe? Can I just undo the fittings holding the pipes to the heads? Any precautions to avoid damaging it?
The real problem that happened last night was, as I was installing the second valve lock, the tool slipped off, and the lock got stick half way and broke in half. I found the half broken piece on the floor, and the other was in the valve stem. So I compressed the spring again to get it out, and I did, and while trying to slip in another lock in, it slips again and this time, it locks up on one valve lock. I have tried numerous times to compress the spring to get the valve lock to just come of, its holding tight. The tool jumping all over the place is dangerous, and to me, safety first!
The tool I used is the OTC tool from Summit http://www.summitracing.com/parts/OTC-4573/?image=large
It worked good for the first 2 springs and then it went all wrong from there. Maybe I messed up, maybe it was cause of the humidity making them slip on each other.
Either way, porting time!
https://ls1tech.com/forums/tools-fab...available.html
I will take the heads apart today and inspect them. Will try to get an electric dremel and bits to do the match porting and polishing tonight. Clean them up and install the new springs. But I cannot get them back on as I have to wait for the $$ to flow in for the new head gaskets and bolts.
Would replacement OEM bolts last or should I go ARP?
Are these the ones I should go for? http://www.summitracing.com/parts/NAL-10105117/
Or these? http://www.summitracing.com/parts/NAL-12553160/
I can't see the difference...?
To the OP, Ive heard great things about that spring tool Badazz 97 Ta linked.
I have also seen some really slick braided SS cross over set ups!! Do a search.
I tried to pull the up, hit them with a mallet to vibrate them a bit loose, nothing would make them budge!
And mine is a 94', where is the block drain plug on my engine?
The block drain plugs are on each side of the block. The one on the passenger side is the knock sensor, and the one on the driver side is a square drive plug.
Make sure you removed all 17 bolts. If they've never been off they will be hesitant to un-seat themselves. Just pry them up the best you can, keeping whatever tool you're prying with away from the deck.
ALL the bolts have been removed, only the 1st one in the front of the passenger side head refused to come out easily, the thread had a lot of white-yellow crud on it (lube?) and I think it was overdone. The other was the last one on the driver side, at the firewall.
Could I stick the wooden handle of an axe into one of the ports and pry it up? Crazy I know, but I bet it would work lol
