Do I need a bigger TB?
Old Aug 25, 2009 | 12:07 AM
boughtitdone's Avatar
Default Do I need a bigger TB?
i have a 383 with all forged internals, 1 7/8 lt, ported heads, carrying around 11 to 1......my question is should i spend the money and buy a bigger tb or is it just a waste of money. it seems to run pretty rich also
Old Aug 25, 2009 | 12:12 AM
kinglt-1's Avatar
Yes you will pick up from a 58mm on your setup. Look into a prefessional products unit.
Old Aug 25, 2009 | 12:15 AM
thats kind of what i was thinkin also how much portin is required to the stock intake for that to fit???
Old Aug 25, 2009 | 12:25 AM
za355tx's Avatar
Wow man with a motor like that I'm surprised you didn't have one already. Yes it will help out some. Nothing crazy but it should help at least a little. You can find good used ones for cheap here on this site. Oh and if the intake is not ported for a bigger TB yet then it needs to be bored. You can do it with the intake and everythin in the car you just need to seal off the intake so no metal shavings get inside. That's how many people do it.
Old Aug 25, 2009 | 12:28 AM
yeah i actualy bought this car done this way and have been diein to do somthin to it...i think my tps is screwy also sometimes it idles good and outhers wtf?
Old Aug 25, 2009 | 10:34 AM
StealthFormula's Avatar
Yea you would definetly benefit from a 58MM unit. If the intake is not already ported internally I would send it to Lloyd Elliott and for $200 he opens up the runners, the TB holes to accomodate the larger TB, and takes some stuff out behind the TB openings. Combined you would definetly get a nice gain with your 383.
Old Aug 25, 2009 | 03:32 PM
thanks for the imput i think that this winter it will give somthin to work on....were is Lloyd Elliot located at
Old Aug 25, 2009 | 03:58 PM
ss.slp.ls1's Avatar
Running rich might be a tune issue...
Old Aug 25, 2009 | 04:44 PM
djjab57's Avatar
Red Oak, Texas
Old Aug 25, 2009 | 04:46 PM
djjab57's Avatar
http://www.elliottsportworks.com/lt1.html
Old Aug 25, 2009 | 05:18 PM
wrd1972's Avatar
Yes, but the gains are minuscule. I had a post where I accurately measured KPA loss and I determined that my current 58mm TB had almost 2KPA less loss at higher RPM than the 52mm TB. Tiny gain but it all adds up.
Old Aug 25, 2009 | 05:22 PM
kinglt-1's Avatar
I agree, but he is going from a stock 48mm unit on a 383. The gains will be a bit better than compared to your situation. A 52 is plenty for most stock displacement setups imo...
Old Aug 25, 2009 | 05:43 PM
wrd1972's Avatar
Did not catch that detail.
Agreed
Old Aug 25, 2009 | 05:52 PM
Bersaglieri's Avatar
I must have missed this thread, it was 52mm vs 58mm and the 52mm was better for 350ci? Just trying to clarify.
-Dustin-
Old Aug 25, 2009 | 05:57 PM
wrd1972's Avatar
-Dustin-
https://ls1tech.com/forums/lt1-lt4-m...-diagnose.html
I used my Datamaster to log the KPA loss under various RPM's and load conditions. I clearly had less vaccum with the 58mm compared to the 52mm.
I also tested with and without elbows and CAI. I also tested my K&N CAI against my old AS&M. It was a good read with some very interesting info.
Old Aug 25, 2009 | 06:07 PM
trx250r's Avatar
^^^a link would be much appreciated
Old Aug 25, 2009 | 06:30 PM
wrd1972's Avatar
Posted it 5 minutes earlier.
Old Aug 25, 2009 | 08:54 PM
I'll be reading it...
-Dustin-
Old Aug 25, 2009 | 11:09 PM
za355tx's Avatar
From everything I've read a 52mm TB is good to handle up to 475 fhwp. That being said if your car makes 406 rwhp then you're probably in that area at the flywheel so a 52 would be fine. Plus that way you don't have to open the manifold at all since the stock bores are already 52mm.
Old Aug 26, 2009 | 12:05 AM
well i supose i should throw in that is also setup to handle a 150 shot also wouldnt i want that extra flow with the 58 for my n.o.s. ive been away from cars for a few years know so ive been tryin to do as much research as possible so i dont look like a noob but if what u are sayin is true then 52 would work with me not adding the shot but with the shot then i need more?????????????
