M6 to Auto swap help
Old Aug 30, 2009 | 06:31 PM
95ztrey's Avatar
Default M6 to Auto swap help
How will a 4l60e with a 4000 stall hold up on 400rwhp??
I tried a search and nothing .....
also what all is needed for the swap ???
Old Aug 30, 2009 | 06:38 PM
1badzee's Avatar
Should hold up fine. Is the transmission rebuilt? 4,000 might be too loose for your setup. See what others are running with similar engine mods. For the swap you will need the crossmember, shifter, shift cable, wiring (either a different harness or modify yours), pcm tuned so the speed-o works, the pedals, torque arm mount bracket (clamshell) is different, and you'll need a flexplate. That should pretty much cover it. Also, a transmission cooler (unless you run a stock style one through an A4 radiator). Oh, and the A4 center console insert piece
Old Aug 30, 2009 | 11:51 PM
dirtynorth's Avatar
How about ill just give you my brand new 4l60e and all that goes with it for your t56 and all that goes with it? I want a 6 speed so bad
Old Aug 31, 2009 | 12:25 AM
dream69's Avatar
Talking
I agree dirty... I say sell your m6 car and find an auto car. I've heard of the switch to an m6 car from an auto not the otherway around. I'd sell it or trade dirty.
Old Aug 31, 2009 | 09:17 PM
95ztrey's Avatar
im also looking for trades
Old Aug 31, 2009 | 11:12 PM
dirtynorth's Avatar
pm sent
Old Sep 1, 2009 | 08:44 AM
the_merv's Avatar
The wiring is a bitch.. I can try to help with it if you need it..
Old Sep 1, 2009 | 02:59 PM
95ztrey's Avatar
That would be awesome !!!!
