Weight reduction
Old Aug 30, 2009 | 09:51 PM
86formula's Avatar
Default Weight reduction
looking to do some weight reduction, what can i pull out of the engine bay/ off of the intake (plugging or not) without creating a vacuum leak or something. kinda want to clean things up and simplify things. this isnt a street car so i dont have to worry about emissions or anything along those lines
Old Aug 30, 2009 | 09:54 PM
C5042081's Avatar
egr,air, ac , also skinnies up front will make a huge reduction
Old Aug 30, 2009 | 10:04 PM
86formula's Avatar
done, done, done, and done. thinking more on the cleaning up side of it. anyone have a pic of an LT1 with almost no Vacuum lines coming from the sides?
Old Aug 30, 2009 | 10:35 PM
litch2004's Avatar
if you have already done the egr there really isnt anything else you can remove off of the intake vacuum wise. The other vacuums are your FPR, pcv, optispark, and your brake booster. You can also remove your abs, cruise control, fuel line relocation mod, LS1 lid conversion, move battery, put your wiring harness, and replace overflow tank with slimmer hidden version.
You could also remove the triangular fenders that are behind the plastic fenders (not a great picture but look at the area that is primer white) :
The other thing to remove is the front crash bar, but i only recommend this on a non-dd car.
Old Aug 30, 2009 | 10:41 PM
ikaros23's Avatar
I've been thinking about the metal braket that holds both the headlight assembly and the top of the front bumper. mine was damaged in an accident and I got one from a junkyard. before I put it on it weighted around 20 pounds. has anybody done something with it or fabricate something lighter to replace it?
Old Aug 30, 2009 | 11:39 PM
dirtynorth's Avatar
there was a super long multiple page thread on this with guys that did way too much weight reduction for their own good.
Old Aug 31, 2009 | 01:04 AM
hitmanws6's Avatar
dont know if you have done this but there is everything in the bumper like the foam and washer tank. as stated the battery relocation with a lightweight battery
Old Aug 31, 2009 | 01:09 AM
Johnny-LT1-runner's Avatar
Rockstar
Go on a diet and do the !car mod, hehehe
Old Aug 31, 2009 | 07:21 AM
86formula's Avatar
The only thing that scares me about pulling the crash bar and everything is something breaking on the front cover
Old Aug 31, 2009 | 07:29 AM
C_Rules's Avatar
Some great info and write ups below:
https://ls1tech.com/forums/drag-raci...y-updated.html
Old Aug 31, 2009 | 07:31 AM
wrd1972's Avatar
Just thinking quickly here. The only real vital vacuum lines you need on a race car are the brake booster and the FPR regulator. Cant think of anything else right now.
Old Aug 31, 2009 | 07:37 AM
Elliott's94Z's Avatar
On top of what you already have done... Rear seat belts, spare tire&jack, maybe a UMI race style K-Member w/ arms which sheds around 35lbs., aftermarket fiberglass hood (mine weighs at least 10-15lbs lighter then the stock) Good luck!
Old Aug 31, 2009 | 09:05 AM
the_merv's Avatar
Veteran: Air Force
How much did they weigh.. I've been thinking about doing that..
Old Aug 31, 2009 | 09:33 AM
litch2004's Avatar
Im not to sure. I still have the pieces that i cut off (minus all the shavings) laying by the car. I will go weight them for you
Old Aug 31, 2009 | 09:41 AM
litch2004's Avatar
i just went out and weighed it and it weighed around 9.5-10 lbs
Old Aug 31, 2009 | 10:14 AM
the_merv's Avatar
Veteran: Air Force
Ah, not too bad. Thanks.
Old Aug 31, 2009 | 10:22 AM
camar0corey's Avatar
10 lbs. per side or 10 lbs. total?
Old Aug 31, 2009 | 10:31 AM
litch2004's Avatar
No problem
no about 5 lbs per side 10 lbs total
Old Aug 31, 2009 | 10:36 AM
the_merv's Avatar
Veteran: Air Force
Yea not really worth cutting off for the function they serve.
They will help when you are parked somewhere and some fat chick decides to lean her gigantic *** up on your car..with the metal there the Plastic Fenders won't shatter..lol
Old Aug 31, 2009 | 11:12 AM
litch2004's Avatar
lmao
