LT1 410 stroker fired up ...videos comming soon
Old 09-07-2009, 04:30 AM
408StrokerSS's Avatar
Default LT1 410 stroker fired up ...videos comming soon
Well after countless hours of cussing...sweating....and throwing money at this car like a fresh 18yr old stripper I finally got the beast fired up. The motor has definitely earned the nickname "Notch" because every last part had to be cut,grinded on or beaten to fit. I am looking forward to getting it broken in and dyno tuned so videos will be posted soon. wish me luck guys
408StrokerSS is offline
Old 09-07-2009, 08:54 AM
Puck's Avatar
Don't see one of those every day. Just curious, what heads are you running to feed that many cubes?
Very cool, can't wait for some vids.
Puck is offline
Old 09-07-2009, 10:45 AM
AChotrod's Avatar
X2 sounds bad ***!!!!
AChotrod is offline
Old 09-07-2009, 10:55 AM
MTBSully's Avatar
wow i bet clearancing was a pain in the a$$. Can't wait for videos
MTBSully is offline
Old 09-07-2009, 11:17 AM
transmaro93's Avatar
still a stock GM block.... this sounds like a crazy build... deff post up vids #'s and what ever else you decide to do with it... good luck man!
transmaro93 is offline
Old 09-07-2009, 01:04 PM
I am running max ported Trick flow heads. The block is a stock lt1 2 bolt that has been splayed with 4 blt Arp studs. It sounds mean guys. Can't wait to get it tuned right. At the moment it is running very very rich. Some FAST engine management is definitely in the near future for this thing.
Old 09-07-2009, 02:08 PM
410 LT1 Stroker, fully balanced,4Blt ARP splayed, Mahle forged coated custom pistons, Eagle 6in Hbeam forged stroker rods, Eagle forged 4in Crank, SFI Racing Damper with KEY, Custom Comp cam dur.292/300 lift.595/.590,double springs, Doug Hebert Racing Double roller timing set, Trick Flow max ported heads, Max ported intake to match,Trick flow oversized valves, comp 1.6 rockers, comp nitrided chromoly 1pc pushrods, comp R Lifters,Clevite Coated bearings, Felpro MLS Head GSKTs, Moroso HV Race pump ,Moroso lt1 oil pan (heavily modified), Ac Delete, CSR Water pump, Delteq ignition, BBK shorty headers,BBK 58mm TB, Yank 3600 stall, Stage 5 4l60E, 02ss 10blt rear end on its last leg, SMJ ABS Delete, hurst line lock.
Old 09-07-2009, 02:12 PM
AChotrod's Avatar
what?? Did you say shortie headers??? Man open that baby up with some LTs!!!
AChotrod is offline
Old 09-07-2009, 02:19 PM
lol ..I know ....I gotta get the funds back up and get a few things taken care of still
Old 09-07-2009, 03:23 PM
flyinZ's Avatar
I thought the same thing, when I saw that.
Id upgrade headers, before I get the engine tuned. Then you only have to tune it once
Sounds like a unique build though, keep us updated.
flyinZ is offline
Old 09-07-2009, 04:02 PM
CBR Crazy's Avatar
Glad to see you about got that thing licked. So I hope we can get some drag strip runs before the end of the year. That will be one time i wont mind looking at tail lights. See you at work.
Kev
CBR Crazy is offline
Old 09-08-2009, 08:51 AM
WS Sick's Avatar
I'd get it tuned first, cylinder wash can ruin a nice build.
WS Sick is offline
Old 09-08-2009, 05:16 PM
flyinZ's Avatar
Not if he has a baseline tune starting off
flyinZ is offline
Old 09-08-2009, 07:54 PM
FASTFATBOY's Avatar
You dont need a FAST system, 94-95 ECM and a 85mm MAF is all you need. That much stroke, that small of a cam aint gonna make any power over 6500 rpm.
Why such a small cam? I woulda put a 270@050 solid roller in that bitch with a quickness. Or at least the biggest hyd roller it could stand.
Why shorty headers? That many cubes needs a 1 7/8 header.
FASTFATBOY is offline
Old 09-08-2009, 10:40 PM
BIG PURPLE's Avatar
good luck i built a 408cid lt1 6 years ago with a pair of ported lt4 heads it made nice power for an lt1. if you have any questions give me a holla.
BIG PURPLE is offline
Old 09-09-2009, 01:48 AM
LT1
LT1's Avatar
What piston, crank, rods did you use on your 408 build?
LT1 is offline
Old 09-09-2009, 07:43 PM
z_speedfreak's Avatar
wheres the vid??
z_speedfreak is offline
Old 09-10-2009, 01:47 AM
Bumper Dragin Bird's Avatar
im trying to do a similar build. what is custom on the pistons? How much did u have to notch the block to clear the rods? thanks
Bumper Dragin Bird is offline
Old 09-10-2009, 07:14 AM
96blackz28's Avatar
Originally Posted by z_speedfreak
wheres the vid??
The OP decided to give us blue ***** and walk away
96blackz28 is offline
Old 09-10-2009, 07:21 AM
Village Troll
SS RRR's Avatar
Especially with Eagle rods.
SS RRR is offline
Quick Reply: LT1 410 stroker fired up ...videos comming soon
