ARP rod bolts?!
Old Sep 8, 2009 | 02:46 AM
yonerhottlt1's Avatar
Default ARP rod bolts?!
So I found some ARP rod bolts for a good price through summit but im still questioning whether it'll be worth it or not. I think it will but my buddy who knows more about this sh*t then i do says it won't be worth it. Im doin a basic rebuild on a stock LT1 block with spun rod bearings and i plan on spraying a 100 shot through this rebuilt block. So to prevent this block from spinning more bearings on spray, i think i should get them just incase. But i just need another opinion on this from an LT guy because i plan on sending this motor to the machine shop tommorrow. Any response is much appreciated. Thanx
Old Sep 8, 2009 | 02:50 AM
1badzee's Avatar
Definitely worth it..
Old Sep 8, 2009 | 06:49 AM
shbox's Avatar
There is no down side to strong rod bolts. It would be a good idea for your situation.
Old Sep 8, 2009 | 08:35 AM
SoxXpupPeT's Avatar
necessary
Old Sep 8, 2009 | 08:37 AM
James Montigny's Avatar
Agreed in this case.
Keeping bearings under control is critical.
Although the higher end bolts (L19 in particular) do require slightly more clearancing on stroker motors.
Old Sep 8, 2009 | 08:38 AM
wrd1972's Avatar
What they said/\
blackhawk0251's Avatar
If your going to be spraying I would definantly use the ARP rod bolts. Fix a small problem before it creates an even bigger one
Old Sep 8, 2009 | 01:54 PM
Alrighty, well im convinced so far. Im not doin anything crazy like a stroker or anything, just all new rings and bearings, hone etc. with stock internals. But even with that said I plan on pushing the motor alot since i havent driven my car in a year now so my right foots itching lol. Plus with me spraying it I figured the ARP rod bolts definitely wouldnt hurt anything seeing that almost every LT motor that ive seen blown has spun bearings.
Old Sep 8, 2009 | 02:52 PM
If your in there doing all of that work I would go ahead and do main studs and head studs while your at it. the Rod bolts will help significantly and if you ever plan on pushing that motor anywhere past 6700 then it would be a smart move.
Old Sep 8, 2009 | 03:18 PM
92camaroguy's Avatar
Do it now while it is apart. I did not and tore it all back down to put them,the $65 ARP bolts cost me a couple hundred. For not doing it the first time.
