gen 1 heads on an LT1??
There are shops out there that will convert them. I would guess it requires welding up existing passages and drilling new ones. Into the water jacket. I'm not too familiar with HOW they do it though, but I do know they can.
Search for a thread I started called "converting sbc heads to reverse flow" and someone posted in there who can do the conversion (a shop).
For Darts, I'd sell what you have and either port a set of stock LT1 heads or pick up a set of Dart Pro1s if you like their castings.
Define "not cheap". I thought it was around $300-$400 ?
Taken from my thread: https://ls1tech.com/forums/lt1-lt4-m...erse-flow.html
Also: https://ls1tech.com/forums/11784805-post30.html
400 bones aint too bad if you already have a killer set of SBC heads. Not to mention SBC stuff is 110930954u7034983409854309543908435908435908435980 53490854 x 3 bajillion more times available
What was that point in that?
For $200 more, you could have had the stock heads ported, milled and assembled, saved yourself the hassel and still had the SBC Dart heads available to sell.
