over the radiator intake setup info needed...
Old Sep 9, 2009 | 07:16 PM
Wicked94Z's Avatar
Default over the radiator intake setup info needed...
i know ls1 speed has this setup. think its possible with 4" oval tubing and a stock hood? i already trimmed some on the radiator and a little on the core support. also what was the filter used because i cant seem to find the "flat"ish filter that i believe ls1 speed has. otherwise ill just throw a 3" cowl hood on the car. pics and part numbers appreciated thanks.
Old Sep 9, 2009 | 10:59 PM
Turnin20s's Avatar
Dr Gas has the pipe, its a 3.5" 1D 60* bend. Then you will need 1 3.5 to 4" coupler to connect the TB to the tube, and 1 3.5" coupler to connect the MAF to the intake tube (PM me I ordered an extra one). Some 18 awg wire to extend the MAF wires, remove your AC condenser, trim the top of the radiator, and remove the underhood insulation.
I had to heat the bottom of the tube to crush it dow about 1/2" so it would clear the stock hood. Then I used a K&N filter and hooked that to the MAF. I'll try to get some pics for you and the K&N part #
Good luck man
Old Sep 10, 2009 | 12:28 AM
Wicked94Z's Avatar
thanks! ac is already deleted, i can have a stainless radiator support made once i get the radiator angle correct because i need to lay it down a bit from the looks of it. im also speed density that simplifies it a little bit i guess. if you could get the filter pn thatd be great
Old Sep 10, 2009 | 02:15 AM
itSSlowZ28's Avatar
do you have a pic of said setup?
Old Sep 11, 2009 | 12:08 AM
Turnin20s's Avatar
I'll try to get a pic up tomorrow, but I have been super busy lately. Fuel pump in my jeep as well as getting water out of it from a leaky seal (carpet is drenched) and a motor swap in my moms jeep. Damn Jeeps LOL
But I'm still using the stock radiator support with a hole cut in it. It had a corner broke of it so I didn't feel bad about cutting it up. Heating up the bottomside of the pipe and crushing it in a little bit helped alot in keeping it under the stock hood without trimming and not having to lay back the radiator more than it already is.
My buddy is suppost to let me use his metal break so I can fab up my new support, but it hasn't happened yet.
But I'll try to get some pics tomorrow
Old Sep 11, 2009 | 01:48 PM
LS1 SPEED's Avatar
not the best pics
excuse the kinda poor trim job on the bumper as it was done prior to me getting the car
Old Sep 11, 2009 | 07:32 PM
flyinZ's Avatar
For some reason, Im thinking the air filter is a "Haltech" filter? Used for corvettes? I dont remember for sure though.
Old Sep 11, 2009 | 08:05 PM
halucinator's Avatar
How well does the fans clear the EWP with laying down the radiator farther?
Old Sep 12, 2009 | 11:36 AM
Wicked94Z's Avatar
when you delete the ac you can put the bottom of the radiator where the condenser used to be, it pulls the whole thing back another 2 inches or so from the ewp. thats what i did at least...
Old Sep 12, 2009 | 11:45 AM
Colin91Z's Avatar
Heres's mine......
Old Sep 12, 2009 | 04:36 PM
itSSlowZ28's Avatar
^^^details? i'm really wanting one of these set-ups. i want to know how hard its going to be to do this myself
Old Sep 12, 2009 | 11:12 PM
cgEvan's Avatar
How does this setup compare to the SLP lid conversion? I've got the K&N CAI and I'm looking for something better.
Old Sep 13, 2009 | 04:50 AM
FASTFATBOY's Avatar
On the back of that pipe where its near the condenser I would have a heat shield tacked on it.
Old Sep 13, 2009 | 10:23 AM
Turnin20s's Avatar
I have driven my car hard for about an hour and then sat in traffic for a bit and the intake tube was pretty much the same temp as the outside air temps. I honestly wouldn't worry about the heat shield, plus theres hardly any room there when you run a bigger filter in there.
I removed all of the plastic shrouding infront of the radiator to get all of the ai into the radiator from the front of the car, and it actually runs a little cooler than it did before.
The filter I used was a RU-3620 and I ordered it at autozone for $38 or so. And I got the reducer and coupler off of ebay.
Pics in a few minutes of mine before I go work on junk jeeps again LOL
Old Sep 13, 2009 | 10:33 AM
Colin91Z's Avatar
I had thought about doing that, but really can't see a reason to. Last weekend when my tuner was datalogging my car, my IAT temps were always 81-83 degrees, even in stop and go traffic, it was 79 degrees that day. I'd say thats keeping things pretty cool.
Old Sep 13, 2009 | 10:35 AM
Turnin20s's Avatar
Sorry mines not as clean as Larrys or Colins YET LOL
And here is where it rubs the hood just a touch after about 300 miles
Old Sep 13, 2009 | 12:16 PM
Wicked94Z's Avatar
good info in here, ill post up pics when i finish building my setup. that low iat sounds pretty good.
Old Sep 13, 2009 | 01:21 PM
94Z28rag's Avatar
Is there an advantage to this over an optimized LS1 lid conversion?
Old Sep 13, 2009 | 01:43 PM
Wicked94Z's Avatar
probably not
Old Sep 13, 2009 | 02:10 PM
litch2004's Avatar
Sorry for the highjack OP, Turnin20s i see you are still using my acc bracket idea and alternator relocation. How is it working out for you?
