making 550hp at the crank come on in
i'm lookin at purchasing heads and cam. i have a 383 forged bottom end short block good to spin 7k . lookin to shift about 6800.would like to use hydraulic roller if not possible thats ok to, any thoughts or someone who has a proven power setup that will make 550 at the flywheel.
Lloyd Elliott is the man to talk to
http://www.elliottsportworks.com/lt1.html
(972) 617-5671
nighttrain66@msn.com
Just tell him you want to be faster than James Montigny
Anticipate $3-4k for a quality setup that will meet your goals, and most importantly, stay together. Good luck with your project!
yea i'm lokkin for people who have 550 to post in this . what do ya'll think of the comp xfi 292 and afr 227 is 550 at the fly wheel possible with this setup
I would highly recommend Ai or LE. Call them with your goals and see what they say. I probably could have saved a lil money had I had done a lil more research instead of diving into this project. To be honest I could have probably gotten a lil closer to 580 at the crank if I went more aggresive with compression but I am gonna spray the ever living **** out of this motor
Im going to go out on a limb here, and say that my setup should be in that HP range.
TFS CnC 215cc heads done by AI, AI HR cam/valvetrain, AI ported intake w/Monoblade TB.. Comp. is something like 11.7:1 on pump gas. Im running on a mail order tune from Ed.
I was shooting for between 575 and 600 flywheel at first, but now it is looking like I will tone down the cam and who cares what it makes, as long as it runs 10s on motor.
