"Flat" LT-specific Crankshaft???
Does anyone make a "Flat" (i.e. - 180 degree) crankshaft for LT1/4 engines?
FYI - Italian V-8s use flat / 180 degree crankshafts vs most other V-8 makers, which use 90 degree crankshafts; and this helps (NOTE: I did not say this was the ONLY factor) those engines rev higher than other engines of the same displacement.
So, that being said, and my desire for a higher redline exposed, does anyone know if a Flat LT crankshaft is available?
(Yes, I do indeed know a new cam and a revised tune is also required)
Although if you still wanted to do it, any flat crank for a SBC with a one-piece RMS will work (or convert to a 2-piece).
FYI - I was told by my brother that a few (non-factory sponsored) Vette / LS-engine based road racing teams have sucessfully used flat crankshafts and gained 500 to 700 extra top end RPMs; hense my curiosity about doing this on an LT-based engine...
I can't confirm your brother's claim, but to be honest I HIGHLY doubt it.
There's no reason a high quality well-assembled conventional rotating assembly can't spin to whatever RPM you want, as long as you have the valvetrain to support it.
A flat plane crank in theory may be optimal, but that doesnt mean you would gain anything in the real world. There have been SBCs that have revved higher than Im sure your looking for, Id just do research on high revving SBCs, im not talking street motors, Im talking motorsport engines, and base your build on some of their ideals.
If your stuck on a flat plane crank their was someone on here looking to do it and found a manufacturer that would do it in sweden I think with a decent turnaround time. (not the engine, a one off crank)
BTW, it's not his claim - he just stumbled on it and then asked me about it - he's a machinist, I'm a Mechanical Engineer; a google search (that's what I did) will confirm that some Vette teams have indeed used flat cranks on their LS engines.
I do not want to argue opinions - too many folks do this here - I just want to find out if a flat crankshaft for my engine exists.
So, given that, thanks for the info (really!
) stating if I found a standard SBC flat crankshaft, then I could use that unit in my LT. I'm a baby blue Pontiac guy, so I thought that the orange Gen I engines were too different from the black Gen II (i.e. - LT engines) to allow for crankshaft interchangability. Trending Topics
http://www.youtube.com/watch?v=E_rTT9PcZ2Y
Also, rotating mass doesn't limit the peak rpm as long as it's balanced. Otherwise, a local engine builder told me a while back that it's very difficult to balance a flat crank because there isn't material to manipulate in the area needing manipulation.
I understand how people like to rev cars alot, hell we all do it. However, how fast do you really want to spin it? Like I said earlier the only reason to spin higher rpm's is to make more power, the issue is you need to be able to make power that high in the rpm range. You are going to need a serious set of cylinder heads, some really serious valvetrain and an absolutly ballastic cam to make it rev that much.
Look at my motor for instance:
Lightweight billet/forged rotating assembly, one of the best LT1 cylinder head offerings out there (AI TFS 215CNC) and a really big AI solid roller (25x/26x .7xx near a 106LSA) and I'm peaking at 7400 with usable power to 7700-7800.
The motor is perfectly durable to those rpms with a strong and lightweight standard geometry crank. Like engineermike said, as long as your balanced the weight almost wont matter. The light weight parts just put less of a load on the mains and rods and will allow the motor to generate rpm quicker. In my engine we actually went with a 51% over balance to reduce high rpm (7,8,9K) vibrations. In case your not familliar with it what you do is split the bob/counter weight 49/51 instead of 50/50. Racers have been doing this for years on longer stroke high rpm motors, the slightly heavier counterweight helps to pull the rod/piston assembly back down the bore at high rpms.
The problem with alot of rpm is even with the best of everything you still stand a much higher chance of breaking things than you do with a lower rpm motor. RPM kills alot more engines than horsepower does. If you do some math you will see that up at very high rpms the force on the rotating assembly increases dramatically per every rpm. Not to mention the speed that the valvetrain must remain stable at.
I'm not trying to rain on the "flat plane crank" parade but I'm just trying to understand the need.
