Speed Inc's Hid kit
https://ls1tech.com/forums/lt1-lt4-m...light-kit.html
thats wut I did, and it turned out perfect.
http://www.ddmtuning.com/index.php?p...=101&parent=60
9006 is the bulb type. Its common in most gm applications. Although you could probably use a different bulb. since you would be using rtv silicone to hold the bulb in place, and not relying on the bulb socket to fit the housing.
