Hmm should I go SR???
#61
Sure. That's what you ran with what... a manly solid roller cam, aftermarket heads/intake/TB/wheels/tires/3800lbs/ so on and so forth, right?
I'm going to try that with my ***** cam with 17" ZR1 wheels up front, 26X16" ET Streets on '97 wheels out back, SLP Level II susp, stock casting heads/intake, at a 3750lb race weight and see what happens...
My cam is HUGE LMAO
Heres yours
248/250 .650/.610 on a 112lsa.
And mine
254/254 650/670 on a 108
LMAO, its SO much bigger! Dayuuum I dont know HOW I streeet drive this monster.
#64
Village Troll
So you say I'll run a 12.20?
My cam is HUGE LMAO
Heres yours
And mine
Heres yours
And mine
You are forgetting those aftermarket heads/intake/TB/wheels and who knows what else. Hell I still have working AC.
I'm just shooting for a goal. You ran 122mph with your 3800lb car with what has already been listed. I'm going to try and run the same mph. I guess that means I'll be running a 12.0 @ 122?
#65
You tell me not to make excuses yet the very next sentence you excuse yourself. Interesting how that works.
Weren't you the one who called my cam a "***** cam..."?
How much power to the wheels does it make? Or have you checked?
I got a streetcar, YOU got a streetcar. Your on motor, Im on motor. You got a 396, I got a 383. Im quicker, your slower...thats about it aint it?
#66
If you're willing to do the maintenance, it can be well worth the effort.
Just make sure you do it right the first time.
Good springs, pushrods, lifters, shaft-mounts, proper tune.... the usual stuff.
Talk to Lloyd, discuss your HR and SR options.
It will become very clear what fits into your description of "worth the investment".
He and I have discussed the pros and cons on several occasions.
#67
11.50 MAX on the first outing, if your lucky. Mph? WHO CARES? Prolly 11.80 or 11.90 in some decent air, which you will probably wait till new years.
He also has something else you wish you had, a 6-speed.
#68
Village Troll
I have a ***** cam. I am wanting to see if my ***** cam w/ what I listed will run at least 122mph. At this point I care about mph. MPH is power. I think you tried to lamely counter argue that point once before and failed miserably.
I am now curious to see if I can run the same MPH with my ***** cam with what I've done compared to what you've done.
I'll worry about ET's later.
#71
Well I wish it was, but these guys are talkin a 2 mph gain from what I already run with 383+ motors with SR cams.
Larrys car runs 126 and mid 10s NA on a HR with a 396 & stock ported heads, Gizmos car runs damn close mph and straight flys ET wise with stock heads intake and TB.
If Im taking lessons its gonna be from them, guys that actually help and straight fly. Im totally willing to take my car to the extent of either of their cars.
Nothing wrong with SR set ups but Im not seeing the gains I was looking for when i can do it with a single cam swap
#72
What is it you want to do? you want a race car or not? horsepower is about the easiest part of the equation when building a car...... you just figure out what you need and do it, making it work is the hard part. Its all just theory and math and equations...
#73
I want a RACE car that could be drivin on the weekends or to the track If I want to.
I dont give a **** about gas mileage or if it can bank 120 corners on the HWY. I think one of my very 1st posts on this site was I bought a 96 Formula WS6 with 27k and want the fastest 350/355 street car possible. Since then the car is far far from stock and the trans is about the only stock part left, but I snapped it in half 2 weeks b4 the shootout had FLT rebuild it and still made the Shootout. There is not one pc of the original motor in the car. Im very dedicated to it and the LTX.
#74
#75
I wish it was that easy.
I want info that will make my **** fly! I dont know every LTXer in the area and for what it is so far my junk runs.
LE and Larry have helped a ton, and I take everything Gizmo says as some of the most helpfull info I can get. If I wasnt stuck on M6 my **** would already be running bottom
11s. Hell it may be close next time I hit the track.
#77
Village Troll
There aren't a whole lot of setups out there to compare since most everyone are too afraid to go solid roller, however you also really can't compare one setup to another if you don't know exactly what you are comparing it to.
#78
If that makes you feel better then by all means.
Seems to me I run 126 mph with a VERY similar cam and I have a stalled auto.
What mph do you think mine would run with a six speed? 129? 130??
BTW before you leap, I DO NOT lock the converter at the track.
#79
AC, do some reading on solid rollers. They are not the high maintenance bitch they once were. Especially if you buy quality parts.
You will make more average power with a solid roller, average power makes a car fast. Especially a heavy(er) car.
Call Bret Bauer, Phil at Ai, Lloyd Elliot. Pick some ears of guys IN THE KNOW about what you want out of the cart vs your experience level.
