Hmm should I go SR???
#81
How about for a pushrod that is 6.125" long? It's either that or like I've stated, it all depends on the application. It is not just the LT1, but any SBC that has horrid valve train alignment/geometry issues.
I have learned I should listen to those who have no experience with SR applications using stud mount rockers on the internet instead of an engine builder who has been building LT1 engines for the last 10 years.![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
As far as solid lifters being taller, it depends on the type that you buy. There are some that are .300 taller, cut-a-way, offset, etc. Also depending on your heads it could change as well, with my RHS heads the angles are revised and the exhaust port is raised so I had to lengthen my pushrods.
#83
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
Not at all. You have the superior knowledge and parts to go with it. I just want to see if I can come anywhere close to when you were at a 3800lb race weight with what I have compared. It just seems you are trying to spin this to where you believe just because you claim my ***** cam is almost the same profile as what you are running then I should be in the same ET/MPH range as you are currently. You've already stated what you think it will run therefore that is my goal. I hope like hell to get into the 11.90 range! Thank you for giving me something to strive for!
#84
LMAO, If that 396 inch solid roller cam dont run 125 mph with a SIX SPEED I would set it ON FIRE.
#85
I emailed Lloyd to see what he has to say, but I think Ill stick to the original plan and get the most out of the current set up, with weight reduction and hooking this thing up, like skinnies mentioned.
In the mean time I will be researching more SR set ups.
#86
But as said before, if you are retarded enough to think my setup is compatible then knock yourself out, champ.
It seems as though you are mouthing blindly. First you say I have a ***** cam and then change your tune to think our cams are now compatible. You then claim I should run close to the same mph w/out a clue as to how I am set up. Funny.
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
#88
That really isn't saying a whole lot about your setup now is it. I mean superior heads/intake/tb/suspension/wheels/tires/etc...
It seems as though you are mouthing blindly. First you say I have a ***** cam and then change your tune to think our cams are now compatible. You then claim I should run close to the same mph w/out a clue as to how I am set up. Funny.![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
It is funny, you compared my SMALLER engine with a stalled auto to your bigger engine with a six speed in the MPH dept. LMAO what a joke.
I dont HAVE to say anything about my combo, it speaks for itself.
Truth is, all day everyday I can outrun you. Step up or step out.
#89
#90
Kinglt,
I know I know......but that damn heavy clutch and drop in HP pisses me off and I want it back!! So my mind starts thinking of what I could/should do. First thought was sell the clutch and get a Spec 3+, but as soon as the car gets sprayed Ill want the ST back anyways.
I really wonder if I dropped a stock 10 bolt and put in a light weight clutch what it would lay down. It will never happen but i wonder. lol!
#91
#92
Kinglt,
http://videos.streetfire.net/video/B...28s_187925.htm
#93
That wasn't in response to you, I just didn't feel like quoting everyone I was answering, I just grabbed the first post and replied.
#94
Ulacovic, SS RRR would argue with a dead rat, if I didnt know any better I would think he was a damn woman.
Every board I see him on its the same old song.
SS RRR, seeing as my car runs quicker than most any STREET LT1's out there on the motor and on pumpgas. You DAMN RIGHT it speaks for itself. Is there any OTHER...REAL streetcar LT1 all motor thats currently quicker? One that can get up on the interstate, drive an hour, make passes at the track and drive an hour home? Larry at LS1 speed is the only other one I can think of. He is close, but is not quicker.
PSSST theres more to come. That aint all thats left in the combo. I got plans.
I found out last night my A/F ratio is 11.5 to 1. I will loosen the converter(seeing as it only flashes to 3600 LMAO), put a 4 hole TB on, retune and look for some low 10's. Stay tuned MPH boy, gonna get interesting this winter.
#96
Mike, that motor will make the same power it did when it loosens up some. Give it some time and get some miles on it this summer.
Mine dyno'd 391rwhp when we finished it 6 yrs ago...pulled the same rwhp this spring when updating the tune and adding S60/28" tires etc. I could care less about dyno numbers excpet when chased gets scared from them...lol
#98
http://www.iimmgg.com/image/1ef558ca...24f40eb0e3e2e8
I believe that was from when you were too belligerent to listen to moderators who told you to cut the trailer trash superior complex **** you and your dad would splatter on. Just leave this to cars and stop bitching while trying to change the subject.
#100
So your gonna be happy about running 122 mph with a solid roller 396 SIX speed?????????? Put a stalled auto in that pile and do it, show me somethin'.
Show me some ET. I took the six speed out of my car. I wanted ET not ricer mph. But just out of curiosity do you think my car would MPH 128 with the converter locked? Hmmmmmmmm.
Buy a damn Supra and roll race.
BTW, I have seen you whining to Bret Bauer on LS1/LT1(BTW his cam profile is in my car), If not mistaken on Speedtalk.
