383 Oil Pan?
Had to move the oil level sensor to clear the hooker headers, but otherwise it worked out well.
I didn't think I could use a stock pan and keep my windage tray with the 4-bolt studded mains.
In retrospect, I probably could have just used the stocker and modified it.
clearance, on mine the #2 rod bolt "slightly" hit front center of pan about 2"-3" from front. I just folded a towel on my work bench, put pan on towel and used a wood base ball bat to make the "indent" useing a 5lb hammer to pound the end of the bat. It took VERY little clearance.
I suggest putting the pan on the block without the pan gasket and have a friend rotate the motor while your ear is against the pan. You should hear contact and see a "witness" mark in the area that needs clearance. When you do bolt up the pan with gasket you then have a additional 1/8" clearance from the thickness of the gasket.
....YMMV
