roller rockers
Old Sep 24, 2009 | 07:36 PM
vegasfbody's Avatar
Default roller rockers
which ones are best to go with without spending a massive amount of money and also pushrods?
Old Sep 24, 2009 | 08:06 PM
lt1-xjs's Avatar
6 years on Promags, almost 2 on Scorpions, I prefer the Scorpions.
Old Sep 24, 2009 | 08:10 PM
Badazz 97 TA's Avatar
Do you want SA or NSA rockers?
Old Sep 24, 2009 | 08:51 PM
stevo9389's Avatar
i think i have the crane energizers. whichever one is the step right below the crane golds and they have been trouble free and quiet for the past 3100 miles. they cost me somewhere between $200 and $230 and were just a little more expensive than the scorpions. as for pushrods i got a set of crane hardened pushrods that cost somewhere around $50. if ya need part numbers i will have to dig them up. mine is a full roller NSA BTW so if you dont plan to rev the **** out of your motor you could spend less than $200 on some good roller tip rockers.
Old Sep 24, 2009 | 09:32 PM
myltwon's Avatar
I have run two of the "cheap rockers" had good luck with both and so does the current owner of my old ones last I checked
-Comp Magnum 1.6 Roller Tip Rockers SA
-Proform 1.6 Full Roller SA
both are under $200 I believe.
SA or NSA's dependancy will vary from application to application, i.e. amount of req rpm. anything above say 6400~rpm I'd recommend to go NSA with guideplates, some will say NSA for anything you do but that is personal preference
Old Sep 24, 2009 | 11:21 PM
vegasfbody's Avatar
whats the diffrence between sa and nsa just nsa better for high rev? my car is stock for the most part just some bolt ons and i wanna do the rockers and get that out of the way for when i do a cam nothing crazy when i do that
Old Sep 24, 2009 | 11:23 PM
vegasfbody's Avatar
also thinking of getting scorpions where can i get them and with these i can jsut use stock length push rods right?
Old Sep 25, 2009 | 01:25 AM
litch2004's Avatar
im running nsa pro mag 1.6. the difference is once is self aligning the other is non-self aligning. Nothing else though that im aware of.
Old Sep 25, 2009 | 01:31 AM
BLK,97,T/A,M-6's Avatar
Why do most guy's hate sa rockers?
Old Sep 25, 2009 | 09:18 AM
StealthFormula's Avatar
They are known to slip off the valve tips at high RPM's. Buddy of mine has a LE1 383 and I told him to get NSA's and of course he never listened. Had the SA's slip off twice and now he finally is getting NSA's. For a bolt-on car SA's are fine but for a cammed car or heads/cam etc. I wouldn't waste the time because your going to have to eventually switch to the NSA's. Been there done that, I should have done it right from the gecko.
Old Sep 25, 2009 | 09:35 AM
myltwon's Avatar
scorpian is another good brand
Old Sep 25, 2009 | 01:14 PM
gregrob's Avatar
I like my Comp Ultra Pro Mags.
But then again you get what you pay for
Old Sep 25, 2009 | 01:34 PM
Jazz-LT1's Avatar
I have some 1.6 Proforms that I will let go for $75.00 -- PM Me...
Old Sep 25, 2009 | 06:19 PM
vegasfbody's Avatar
i wanna get some scorpions where can i get them from? and some pushrods aswell
Old Sep 26, 2009 | 10:07 AM
myltwon's Avatar
summit sells scorpion rockers
as for pushrods 7808-16 Comp Cams Hi-Energy hardened pushrods, 7.200 (OEM Roller - Factory Length) $29.75 brand new from summit
Old Sep 26, 2009 | 10:08 AM
sepno77's Avatar
ebay has them.
Old Sep 26, 2009 | 07:44 PM
vegasfbody's Avatar
got a part number for the scorpion rockers?
Old Sep 26, 2009 | 07:54 PM
ABA383's Avatar
I have 14 years on my Comp hi-tech stainless rockers...Probably the best/durable rocker out there...I think they are a bit more money than most, but well worth it...
--Alan
Old Sep 26, 2009 | 09:11 PM
myltwon's Avatar
just go in summit, select 1994 Pontiac Trans Am and look for rockers under valvetrain, it's not that hard. just make sure you look for 3/8 stud unless you plan on upgrading to 7/16 studs
Old Sep 26, 2009 | 10:03 PM
vegasfbody's Avatar
i dont know if im doing somthing wrong but theres like absolutly no rockers on there and when i go to camaro there is only comp
