How long to break in the clutch?
Old Sep 25, 2009 | 11:18 AM
93TAJ.C.'s Avatar
Default How long to break in the clutch?
Iv got a new clutch. just the stock replacement. How long do i neeed to take it easy?
Old Sep 25, 2009 | 11:59 AM
Wicked94Z's Avatar
500 miles
Old Sep 25, 2009 | 01:43 PM
riceburnerZ28's Avatar
500 easy miles. FWIW I just reached 4k miles on my stock replacement clutch and already it's starting to slip bad. So be careful with hard launches!
Old Sep 25, 2009 | 05:00 PM
93TAJ.C.'s Avatar
Thanks guys
Old Sep 25, 2009 | 06:25 PM
porksoda's Avatar
You need to take it easy until you get a stronger clutch! LOL Seriously though as said the stock clutch won't put up with hard launches for long.
Old Sep 25, 2009 | 06:29 PM
kinglt-1's Avatar
yep 500mi and try not to slip it at all during the break in period.
Raven97's Avatar
just get some really cheap non-sticky tires and practice your powerslides then when the tires are gone the clutch will be good to go!
Old Sep 25, 2009 | 06:45 PM
BALLSS's Avatar
OP
stock clutch should work fine with the mods in your sig. 500 mi of "normal" driving before you beat on it.
riceburner
a stock clutch with your sig mods would start to slip....move up
Old Sep 26, 2009 | 10:19 AM
93TAJ.C.'s Avatar
Well I live in colorado springs, so im losing some power, and iv still got 3.23's for now with a weak posi. So even my old clutch never slipped, it just broke in half lol. But it was still the clutch that was in the car from the factory and the disc looked like **** compared to the new one, they wer totally different designs and the new one looked beefy. Im probubly only making 30x at the wheels, do you still think it could slip? I will upgrade the clutch when i do a bigger cam and some 3.73's next summer or maby even this winter. I'm just broke, the disc and 80 grit sandpaper came to 70 bucks, so i had to do it to get on the road.
Old Sep 26, 2009 | 10:25 AM
93TAJ.C.'s Avatar
I just realized I dident give you guys the story. It broke hitting third at 70, it wouldent go into 4th and it was because the metal disc broke in half packing the disc material into the pressure plate and seizing the cluth together. When I got it all apart everything was ok but the disc, the flywheel and pressure plate are nica and flat and had minimal burning and no pitting. So all I did was buy a new disc, and take some 80 grit paper and a DA to the flywheel and pressure plate surfaces. I then used a block sander and some more 80 grit to give them both a nice cross hatch pattern like they have new.
I know alot of you are probubly laughing, but I have 4 bucks to my name, I'm a mechanic, and I sold my other daily driver just so I could keep this car. The clutch feels nice and smooth so far.
Old Sep 26, 2009 | 11:21 AM
94Z28rag's Avatar
Just drive around on a good mix of roads for about 500 miles, as stated before.
Old Sep 26, 2009 | 12:02 PM
946spdz's Avatar
Dont get a zoom they come bad from the factory
Old Sep 26, 2009 | 12:54 PM
SoxXpupPeT's Avatar
spec stage 2, 500 bitch miles. 5k on it and still holding like a mother.
Old Sep 26, 2009 | 02:58 PM
DBurgLT1's Avatar
The first time I went to the track with my stock clutch i blew it apart on the second launch Now I have a spec with around 7000 and it still holds great!
