Crank Hub Bolt
The crank is a Callies Dragonslayer unit, would the threads be different?
As mentioned above, be sure to clean and chase the thread.
Try to find an automotive grade (black) bolt to replace the old one.
You want something you can torque and that won't rust.
I've picked them up at the local hardware store.
Don't try to run without one; even though the hub is pressed in, it will come loose.
(ask me how I know)
Period.
OP, what you need is a grade 8, 7/16-20 bolt that is 2 1/4 inches long. A little shorter, or longer wont work.
Go to Fastenal and ask them for that size in a grade 9, if they dont have it they can order it.
(Dont get confused with the grade terminology, "grade 9" just has a little higher tensile strength and has a fewer better design features that make them a maintenance grade fastener, which is a step above OEM.
If you dont have any luck that way SS RRR has some extra stock ones, or I can send you one at worst. (I sell fasteners for a living).
Took the underdrive off, got the hub seated all the way and the bolt went right in. With lots of locktite of course. LOL
