Replaced Opti, Coil and ICM but still a problem.
Replaced the everything including wires but when I start driving around for a bit it starts to bog down when im at idle like I have a cam almost. Then I give it gas and it fights through the throttle a bit then it gets up to speed. Cruising is ok for me to do but WOT it is hesitant, but makes it to 6k.
I replaced the following so far.
Opti Ebay
Coil MSD
ICM
Wires MSD
O2 sensors
Will be replacing when I get off class today
Fuel pump (Walbro)
Fuel pump harness Racetronix
The fuel pressure is at a low 38psi, would that cause it run like it does? Should I replace the plugs also? Im so lost with this car lol
Its a 93' btw. Thanks guys
Opti Ebay
Coil MSD
ICM
Wires MSD
O2 sensors
Fuel pump (Walbro)
Fuel pressure at WOT (vacuum unplugged from FPR is 48psi)
you get what you pay for some times...my car was doing the same thing ill have it in 1st gear my car it and m6 and i give it gas WOT when im rolling at 15mph and the car just boggs and fights through the throttle then at about 3500rpm it pics up and goes...i replaced the opti with a gm one and the problem is gone...but yours is a 93 right you might just have the timeing off on your opti ....it does not hert to take it off and double check b 4 you go spend more and more money that you dont need to
How would I go about checking this anyway?
hey i got a queston, when u give it full throttle does it get almost to a shifting point and then act like its not gonna shift and kinda spudders? bc thats the problem im having. i just replaced my opti too. and my fuel filters, next ima try plugs and wires. LMK what u find out
I was having similar problems. I had a bad opti, and warped heads. Have you tried doing a compression check?
I also put in my opti wrong as well. Yes there is the key, but I missed the hole and got it into http://i34.tinypic.com/akbw5z.jpg, where the red dot is. The opti shouldn't be able to shake around, like mine did.
Edit: I wasn't getting compression in one cylinder.
I have a 93 so the back of the Opti is splined shaft with a key way so it can only go in 1 way.
When I put the opti in it didnt seat completely, it had about 1/8" gap before it could be seated all the way. Could that cause pressure on the opti and act like this?
I would check any of the componets you mentioned wiring, it is OLD. Something may not like how it was reassembled. Definitately check the tps for voltage and replace the fuel filter
The pump and harness is in and good. Its runs good, but breaks up at WOT and i feel a slight stumble at idle now. Im gonna say its the plugs/wires on this one maybe.
