Crate LT1
Old Oct 11, 2009 | 07:57 PM
huggmess's Avatar
Default Crate LT1
Bout how much would you guys pay for one that was complete except valve covers and accessories and zero miles...I have the chance to get one and want you guys to tell me how much it's worth without me telling you how much he wants for it
Old Oct 11, 2009 | 10:03 PM
robsquikz28's Avatar
bone stock with a great rebuild that was just a long block and bolt up accessories....I would pay $1500 for it. ITs complete right intake, injecors, flywheel, waterpump, egr valve????
Old Oct 12, 2009 | 12:32 AM
stevo9389's Avatar
i paid just under $1100 for a factory new 4 bolt short block less than 8 months ago and i thought that was a deal.
Old Oct 12, 2009 | 12:03 PM
huggmess's Avatar
It's a factory zero mile crate motor with intake, injectors, everything but valve covers and the usual accessories...he wants 850...I guess I oughta get it
Old Oct 12, 2009 | 01:30 PM
96lt1m6's Avatar
i would buy it then disassemble it and put performance bearings in it, knowing me i would do forged pistons and new H-beam rods also....
however that all depends on what you are planning on doing with the car.
Old Oct 12, 2009 | 01:46 PM
MasterTomos's Avatar
do it
Old Oct 12, 2009 | 03:13 PM
nik1703's Avatar
do it like they do on the discovery channel
Old Oct 12, 2009 | 04:13 PM
am_muscl's Avatar
how is this guy getting crate motors? I want one!!
Old Oct 12, 2009 | 04:26 PM
huggmess's Avatar
Haha...I prolly am...it's just some random mechanic that came into my store and got to talking to me about my camaro...said he got it for some old lady's impala and before he put it in she died...sooo...I hope he's not full of sh*t and it's actually what he says...I could prolly even talk him down some more on the price
Old Oct 12, 2009 | 06:55 PM
transmaro93's Avatar
if its for an impala... its probably going to feel alot slower than your stock engine... due to the heavier iron heads, a weaker cam (that usually came in them), and i believe they had a lower compression ratio also.... just a warning for you... im not an expert so correct me if im wrong fellas but i believe those were the big differences in the camaro/firebird lt1's and the impala lt1s.......
Old Oct 12, 2009 | 09:55 PM
pillarpod's Avatar
its from impala? i say no touchy touch....but that IMO
Old Oct 12, 2009 | 10:04 PM
fuzzyjk's Avatar
I bought a newly rebuilt LT1 from a Impala for $1200.00 including everything from injectors to the alt even a new belt.
Please confirm if it has lower compression because I plan to use a supercharger on this stock engine w/head cam package.
Old Oct 13, 2009 | 12:46 AM
camaroz28383's Avatar
since it was for an impala make sure it is a 5.7 and not the 4.3 the casting number on the block for the LT1 is 327
Old Oct 13, 2009 | 10:19 AM
huggmess's Avatar
If there's that big of a difference in the impala lt1's and camaro lt1's i'll prolly just steer clear...I was under the assumption they were all pretty much the same
Old Oct 13, 2009 | 10:29 AM
96blackta's Avatar
I have very little trust for any mechanic I don't know personally. He's probably trying to pull one over on you... I bet he knows the difference between the motors.
Old Oct 13, 2009 | 10:41 AM
stevo9389's Avatar
if it was for an impala it should be a real lt1 if it were for a caprice it is most likely a l99. dont freak out it is probably a good deal you will just have to deal with iron heads and straight plugs unless you have a good set of aluminum heads to swap over
Old Oct 13, 2009 | 04:34 PM
huggmess's Avatar
I was gonna pick it up and drop it in a s-10 or maybe pick up a 67-72 full size...who knows
