lowering with true duals ***post pics***
Old Oct 12, 2009 | 11:16 AM
baylove's Avatar
Default lowering with true duals ***post pics***
whats up guys have some questions about lowering the "Z" with true duals i like the lowered look but i dont want to rip my exhaust off or damage anything whats TOO LOW with our cars ?? its a guy locally that has some eibach sportline lowering springs will that make my car too low with true duals? can you guys post pictures of your cars lowered with true duals and let me know what you have for suspensions mods PLEASE THANKS IN ADVANCE
Old Oct 12, 2009 | 11:27 AM
Colin91Z's Avatar
I'm running Sportlines (in these pics anyways) with true duals, I've never scraped my exhaust...
Old Oct 12, 2009 | 11:28 AM
dirtynorth's Avatar
I dont have true duals but my car is lowered 1in in the front and 1.5 in in the rear and i bottomed out my 3in y pipe coming out of a parking garage and now I have a really fail exhuast leak. So i wouldnt even chance it with true duals.
Old Oct 12, 2009 | 11:33 AM
wrd1972's Avatar
I have TD' (see sig) on mine but I am stock ride height. IMHO, at least with my setup, the LT's ground clearance is the primary concern. My TD pipes just before the axle are much higher again than the left LT header.
So if you can focus around the left side header clearance, the TD's can easily be made to work.
Old Oct 12, 2009 | 12:42 PM
baylove's Avatar
Colin91Z did you take your sportlines off ? if so why ?
Old Oct 12, 2009 | 01:20 PM
Colin91Z's Avatar
Because they suck for drag racing. I still have them on the rear for now, but the fronts are getting replaced with Strange SA's w/ matching coil-over springs.
Old Oct 12, 2009 | 01:26 PM
baylove's Avatar
so the sport line springs suck for drag racing why is that ?? so there only for looks ?? are they better then the stock springs ?
Old Oct 12, 2009 | 01:39 PM
Colin91Z's Avatar
Its not that they suck, they're just not intended for drag racing. When combined with a stock shock or a stiffer shock, Sportlines are better suited for cornereing/handling. Like roadrace, autocross, etc.
They're better than stock for their intended purpose, but are not the best out there.
If drag racing is your gig, I'd look to something like a QA1 or Strange shock/spring combo to give you not only the ride height your looking for, but the performance as well.
Old Oct 12, 2009 | 02:26 PM
baylove's Avatar
mainly a street car and occasional track days not a full blown drag car
Old Oct 12, 2009 | 05:07 PM
nik1703's Avatar
How much lower is the 1LE suspension, if at all?
Old Oct 12, 2009 | 05:54 PM
mcalus's Avatar
There is a 30+ page with tons of pics in the LSX externals. Its a sticky...
Here is the link....https://ls1tech.com/forums/generatio...-pics-too.html
Old Oct 13, 2009 | 03:47 PM
monster81's Avatar
i've cut half a coil from the top of the front and rear springs, car is about 1" lower overall but i also have 28" O.D. rear tires on 15" wheels. clearance is not too bad with my TDs, here a couple of pics of my setup
Old Oct 13, 2009 | 05:02 PM
nighthawk15's Avatar
I wouldn't put sportlines on any f-body because they're too soft for how much they lower the car, but that's beside the point. I'm lowered a little over an inch on strano springs and have 3" dumped duals. I only scrape on really nasty *** driveways and big speed bumps. I'd go get pics of the clearance but to be honest I'm sick and lazy right now.
Old Oct 13, 2009 | 06:41 PM
StealthFormula's Avatar
I have the Strano 1.25" lowering springs on my car with 2.5" TD's and I have never scraped my exhaust except for one of my turndowns when I hit a bump in the road going too fast. The clearance is even better than when I had my 3" ORY and if I ever scrape anything it's just my air dam upfront.
Old Oct 13, 2009 | 07:18 PM
96lt1m6's Avatar
only a 1" drop out back,the 19s make it look stock height
Old Oct 16, 2009 | 12:59 PM
baylove's Avatar
ok so sportslines are worse then stock ?? get well soon man hope you feel better
Old Oct 16, 2009 | 01:09 PM
baylove's Avatar
i basically want to lower the stance of my car but i dont want it to be sloppy
Old Oct 16, 2009 | 07:39 PM
integraxtc's Avatar
If this is sarcasm...
You missed his point. Sportlines are TOO SOFT FOR HOW MUCH THEY LOWER THE CAR.
If you're going to lower the car more than 1.2" then you need a really stiff spring/ paired w/ the proper shocks so they won't bottom out.
Stocks are softer, but they don't lower the car, so hence why you don't bottom out.
Old Oct 16, 2009 | 10:57 PM
baylove's Avatar
sarcasm about what ?? it was a question and he said he was sick so i dont know what your talking about anyway thanks for answering my question
Old Oct 18, 2009 | 01:45 PM
integraxtc's Avatar
It may have been on PM, but I didn't catch where he said he was sick.
So, this being the internet and all, it's hard to pick up on stuff like, sarcasm.
I took it as, "So you're saying, stock springs are better than Sportlines? OK(sarcastic OK) You must be sick and I hope you feel better for suggesting that"
catch my drift. It's all good.
