403rwhp 387ft-lbs LE1 heads LE Intake 306cc w/ m6 through a 9" moser!
Old 10-13-2009, 11:55 AM
94Z28rag's Avatar
Not bad, but I'd like to see a MPH number.
Old 10-13-2009, 02:38 PM
Moderator
BizZzatch350's Avatar
Those numbers are stout! Many of guys with your exact set up are lucky to put that to the back tires with a 10 bolt much less a 9 inch. With a TH350 and a 3800 stall, the dyno isn't worth much, the track how ever will be your best friend.
Old 10-13-2009, 03:06 PM
djm_e22's Avatar
Originally Posted by texas94z
Good numbers man.
Why are going to run a t350?
Cause everyone keeps telling me a stalled auto will run alot faster. If I'm not mistaken the 4l60e will run faster NA due to the lower 1st gear compared to the th350. But I plan on using 150 shot of nitrous and believe the th350 is geared better for the nitrous and should be faster on nitrous. Is this correct?
Old 10-13-2009, 03:24 PM
myltwon's Avatar
actually your rear gears might compliment a th350 nicely
Old 10-13-2009, 04:07 PM
Bersaglieri's Avatar
I'd personally dont like the drop in gearing the 4L60's use.
-Dustin-
Old 10-13-2009, 04:34 PM
BADMOON's Avatar
My advice keep your exact gear and if you wanna be a faster track car go with the TH350 and spray that will be a perfect combo for your power level. Dont go TH400 they rob too much power and a TH350 can b built plenty strong. Me I like driving my car around I keep my 6 spd.
Old 10-13-2009, 08:57 PM
LS1TECH Sponsor
NightTrain66's Avatar
great #'s with that cam and $900 heads.
Lloyd
Old 10-14-2009, 02:25 AM
robsquikz28's Avatar
wow, that engine is stout as hell. you beat a lot of LE2 and LE3 peeps out there,lol...wow is all I can say and props to LLoyd again ^
Old 10-15-2009, 12:38 AM
blackz93's Avatar
Originally Posted by wrd1972
You also have that tiny dip in the torque between 4K and 4.5K RPM just like I do. I have seen this in many charts. Although I dont consider it a problem. Someone explain what that is.
Just looking at my chart and it doesn't do that.
Great numbers OP... get that thing on the track!!
Old 10-15-2009, 04:28 AM
udlose99ta's Avatar
You will lose quit a bit of rwhp by going to the th350 route, but it won't matter because they car will be quicker in the 1/4. I personally love the stalled suto over m6 but I'm also at the track every weekend. Fun either way
Quick Reply: 403rwhp 387ft-lbs LE1 heads LE Intake 306cc w/ m6 through a 9" moser!
