Burnt MSD wire, what are my options?
Old Oct 18, 2009 | 09:31 PM
whytryz28's Avatar
Default Burnt MSD wire, what are my options?
My #5 header primary is dangerously close to the wire, but not touching it, but close enough to were it cracked the red insulation but not through to the core.
Im guessing that im gonna have to buy a new set just for 1 wire aren't I?
Old Oct 18, 2009 | 11:01 PM
robsquikz28's Avatar
Or you can buy a set of 8 that I have!!! Look in the non lsx section, or yes you can buy 1 and try to buy a boot protector and Try to save it.
Old Oct 19, 2009 | 12:49 AM
whytryz28's Avatar
What boot will fit over the MSD wire though, the one from DEI is to small.
Old Oct 19, 2009 | 10:49 AM
happysem's Avatar
Mine did the same thing, it looks singed (slightly flat) but I don't think it went through, although I could see a spark between it and the primary
Am I screwed on that one?
Old Oct 19, 2009 | 01:57 PM
96blackta's Avatar
When that happened to me, I just bought a pair of MSD boots, cut the old ones off, and re-crimped them with pliers.
Old Oct 19, 2009 | 04:06 PM
sdotlog's Avatar
if you need one wire. you can get a hold of 99blanco ss. he can hook you up.
Old Oct 20, 2009 | 08:05 AM
quik95lt1's Avatar
i got a new set of 8 for sale as well as 6 extra older ones....check out my parts post
Old Oct 20, 2009 | 09:03 AM
airfix's Avatar
Get a hold of blanco 99ss He's a sponser on here and he makes/crimps msd leads He will be able to help you out for sure.
Old Oct 20, 2009 | 09:04 AM
airfix's Avatar
The wire is arching, so yes get a new lead.
Old Oct 20, 2009 | 01:06 PM
slingshot928's Avatar
My friend bought the crimping tool, so for my car I bought a 25 foot roll of msd wire, and some ends...wherever I want to run the wires, they will go....its an expensive way if you have to buy the tool, I think that was like 80 bucks. See if someone can get you a single wire.
Old Oct 20, 2009 | 08:50 PM
happysem's Avatar
I replaced my stock wires with just normal replacements (bad phrasing, don't care) should I just get another wire like you guys said, or go bigger like the MSD 8.5mm? I'm just intake/full exhaust.
Either way, I'm going to do the OTVC treatment to ensure this doesn't happen again.
Old Oct 20, 2009 | 09:20 PM
Elliott's94Z's Avatar
Bro I have a butt load of MSD 8.5mm SD wires laying around my house. Send me a pic of the #5 wire, which I'm sure I have (can't picture which one that is off the top of my head) and I will mail one out to you free of charge. I have both red and black wires.
Elliott
Old Oct 20, 2009 | 11:54 PM
whytryz28's Avatar
Elliott
Its still on the car (need it running) but ill try to get some pictures of it.
Thanks
Old Oct 21, 2009 | 06:58 AM
koolaid_kid's Avatar
I just replaced my #5 wire (ham-handed removal damaged it). It measures ~24" long, tip to tip.
Old Oct 21, 2009 | 09:15 AM
Thanks
Good deal man..
