water mixed with oil on my cap
went to add oil to my car and i saw this..... i have had smoke come out of my car at wot. i checked the dip stick to see if it looked like this and it looked fine.
May or may not be a problem. Water can collect there if the the engine oil wasn't brought to operating temperature and run long enough to allow the condensation in the oil to 'boil' off. If you don't have water on your dipstick or in the oil upon draining it you should be okay.
A pressure check of your cooling system is the proper way to check for a head gasket or other problem.
I used to see this at work all the time this time of year (a lube express)...especially during humid times/radical changes in weather in where you live, along with what kind of oil you use.
We saw this a lot with penzoil, quaker state, and castrol products way more often when compred to others such as mobil, valvoline, and havoline.
What type of oil do you happen to be using?
