Easy one for you guys. Easiest way to relieve fuel pressure to change fuel filter.
So what do you think? I don't really want to go digging inside the footrest thing to get to the relay. thats where shbox said it was at.
what do u guys do?
what do u guys do?
All you need is a 20 and 16mm wrench along with a set of needle nose pliers (easier) and your set. Its not a big thing to do at all just loosen the threaded side first and let the pressure bleed off if your so worried about getting gas everywhere. Its easy as pie.
On the back of the fuel rails there is a pressure relief valve - very similar to the valve on your tires, push that (have a rag to catch all the gas) - Ta-Da! Pressure relieved!
Just take the thing off.. It's not going to blow up if you dont' do a dance, flip the accessories off and on, take a dump while blowing your nose, etc.. It's not on, there isn't any ungodly pressure..
There is a guide on my site for replacing the filter. It tells you just what to do. I don't say anything about messing with the relay, though. Not sure how you got that. ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
http://shbox.com/1/fuel_filter.html
Or you can undo the quick snap and be done in two seconds and get a shower of gas.
