lt1 valve hitting piston
Old Oct 25, 2009 | 01:35 PM
Burning Rubber's Avatar
Default lt1 valve hitting piston
i just tried to adjust the valves on my new heads/cam lt1 and when i went to turn it over i can hear the valve hit the piston. I cant understand why. It has trick flow gen x heads/10.5to1 keith black pistons/5.7 h beams/CC306 cam/mr gasket mls head gaskets/7.2 inch push rods and 1.6 roller rockers.
the only things that are different from the old motor are the heads/connecting rods/pistons. everything else is the same. Anyone else ever have this problem?
Old Oct 25, 2009 | 01:51 PM
James Montigny's Avatar
Unless the cam timing is way off or the pistons in backwards, you should not be having P/V issues in an LT1.
Old Oct 25, 2009 | 01:58 PM
Thats what I thought. I have never heard of anyone having this problem but the pistons are in correctly and the cam timing is correct.
Old Oct 25, 2009 | 02:09 PM
fleetmgr's Avatar
Have you checked to see if it does it with all cylinders, or only one? Maybe a mislocated wristpin?
Old Oct 25, 2009 | 02:59 PM
no I havent checked any other cylinders yet.
Old Oct 25, 2009 | 03:54 PM
I am wondering what would be the best way to fix the problem. Should I change back to 1.5 rockers or get a thicker head gasket?
Old Oct 25, 2009 | 04:07 PM
That's a bandaid ... find out why it's hitting. Something is wrong somewhere.
Did you happen to measure deck height when you built the motor?
Are those pistons designed for the crank you are using?
Old Oct 25, 2009 | 04:23 PM
stevo9389's Avatar
you did replace the timing components right? think there was a chance you tightened a rocker too much?
Old Oct 25, 2009 | 04:35 PM
wrd1972's Avatar
Something bad wrong here.
Old Oct 25, 2009 | 08:12 PM
gregrob's Avatar
Check cam timing
