Help with reverse lights
Old Oct 28, 2009 | 06:34 PM
mighty mex's Avatar
Default Help with reverse lights
So I had to change my complete engine wiring harness because my original one was just beat to hell and melted on the pass. side header. The only harness I was able to find was from a '97 automatic car, my car is a '97 6 speed car. Everything works but the speedo and reverse lights. Does anyone know what wires i need to hook up from the automatic harness? Thanks in advance.
Old Oct 28, 2009 | 07:12 PM
Spartan7's Avatar
The 16 gauge brown and green wires on the A4 shifter connector go to the reverse light switch.
Old Oct 28, 2009 | 07:33 PM
the_merv's Avatar
^^He has a stick car..so he has no auto stuff..
You are going to have to wire that Connector into the Harness..basically get a pinout of your Harness Connectors and find the Reverse Light & 12v Power Wire that is on the car side in the Connnectors there under the Glove Box. Use a Test Light to find the power, the Rev. Light wire is Lime Green. Once you have found them you will have to line them up in the Engine Harness.
I don't know why the Speedo won't work..that's wierd.
Old Oct 28, 2009 | 08:23 PM
tbag_skywalker's Avatar
hey merv,
i might be saying what youve already said but...
wouldnt it just be easier for him to cut the reverse light connector off his old harness and splice it to the new one?
My car was an automatic and I did the swap a few years back, and if I remember correctly all I had to do was crimp the 2 leads off the reverse light connector to the brown and green wires on the a4 shifter connector (obviously I had to dig the brown and green wires out of the a4 shifter bundle and cut them off at the connector).
Old Oct 28, 2009 | 09:25 PM
the_merv's Avatar
Man am I the only one that caught the fact that he is a MANUAL.. Read you blind fools..
What I said is what he needs to do.
Old Oct 29, 2009 | 12:22 AM
Spartan7's Avatar
I mixed them up, I thought he was swapping.
You need two wires that are inside the car. A brown wire off E1 on the fuse block, and the light green wire that runs all the way back to the reverse lights.
Old Oct 29, 2009 | 12:31 AM
the_merv's Avatar
Those 2 Wires will be in either the Blue or White Connectors. The easiest way to find out is to strip them and the connector out of your messed up harness and put them in the new harness in the same exact spot.
Old Oct 29, 2009 | 02:33 PM
mighty mex's Avatar
Thanks a lot the merv. I kinda had a feeling that was what i was going to have to do. i was just hoping there was another/easier way out. good thing i still have the old harness. thanks again fellas
the speedo doesnt work cuz the speed sensor is not connected, on the trans. so basically im thinkin im gonna have to do the same to the speed sensor like the rev. lights
Old Oct 29, 2009 | 03:07 PM
the_merv's Avatar
The Auto doesn't have the Speed Sensor Connector in the Wiring?
It is the same as the T56, BTW.
Old Oct 30, 2009 | 05:40 PM
mighty mex's Avatar
i dont remember seeing the connector. gonna have to double check. thanks again.
