new PB...sooo close to the 9's
Old Nov 2, 2009 | 11:32 AM
LS1 SPEED's Avatar
Default new PB...sooo close to the 9's
I drove the car over an hour to the track yesterday in with hopes for a 9.99 pass.
150 shot
110/93 in fuel tank
116 in dedicated
20 degrees of total timing
11.8-12.0 A/F
275/60/15 M/T radials
1st pass
1.32 60 ft
10.07
131 mph
The car wheelied pretty good and just bumped the limiter on the 1-2 shift which is 7300 ( window switch @ 7100 )
2nd pass NPB
1.34 60ft .. big wheelie and people said I set the front end down after the 60ft marker
10.05
132 mph
bumped limiter on the 1-2 shift again, so it was no fluke
I then got Jim ( our tuner ) to lower the 1-2 shift, put 2 degrees of timing in and added a touch fuel at the dedicated. There was a delay due to a clean up and the sun went down and the track went away.... so I spun and just went home
I had a great day and still very happy with the car. The air was 500-1000 for the day. The converter seems to be a little too loose, so over winter I'm going to make a few small changes to better the current combo.
Old Nov 2, 2009 | 11:39 AM
WhitePhoenix99's Avatar
Very impressive, killer 60ft
Old Nov 2, 2009 | 12:12 PM
Tony Shepherd's Avatar
Good job! You have that car hooking!
Old Nov 2, 2009 | 12:14 PM
Colin91Z's Avatar
Nice!
Any vids?
Old Nov 2, 2009 | 12:28 PM
Z-RATED94's Avatar
Pretty cool Larry, but I think a 10.00x is coming before that 9 second run happens. Are you going to wait for a better day and give it one more try this year?
Old Nov 2, 2009 | 12:30 PM
BizZzatch350's Avatar
Moderator
Bad *** Larry, that car works good.
Old Nov 2, 2009 | 12:32 PM
StealthFormula's Avatar
That's awesome man, nice job!
Old Nov 2, 2009 | 12:33 PM
dlk1950's Avatar
Great runs...9s are right there.
Old Nov 2, 2009 | 12:50 PM
LS1 SPEED's Avatar
thanks guys
The window switch was only at 4100, so there is still more it it. I feared going on the bumper though without having my limiters on yet.
I think fixing the 1-2 shift and the 2 degrees of timing would have done the trick, but who knows.
this weekend I'm not racing, but if weather works I may try 1 more time
Old Nov 2, 2009 | 02:24 PM
Speed Density's Avatar
hashtagBMW
Get it done, Larry! That car is bound for an easy 9.99 pass.
Old Nov 2, 2009 | 03:12 PM
sweetbmxrider's Avatar
niceeeee
what's your race weight?
Old Nov 2, 2009 | 03:49 PM
AChotrod's Avatar
A stiff tail wind would have you in the 9s. Any vids?
Old Nov 2, 2009 | 04:59 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
grats Larry......nice seeing all of these quick LT1 time getting posted.
Old Nov 2, 2009 | 05:23 PM
LS1 SPEED's Avatar
about 3400# in full street trim as raced ( 4" catback on and pass seat in place )
We actually had a decent head wind yesterday, so that didn't help at all.
thanks for the props guys
Old Nov 2, 2009 | 05:49 PM
James Montigny's Avatar
Very impressive Larry.
I guess you'll be on a diet all week trying to shed 10lbs LOL
Old Nov 2, 2009 | 05:56 PM
Black94Z28's Avatar
Congrats on the times!
Old Nov 2, 2009 | 06:50 PM
n2ocamaro's Avatar
Nice job Larry. Those 60' times are impressive. Hope you get it over the hurdle before winter.
Old Nov 2, 2009 | 07:01 PM
LS1 SPEED's Avatar
thanks
I am going to go out if the weather works with me the 14th or 15th.
The car will sit the same in full street trim and go for a 9 sec. pass. I know the car has it in it as it sits. The exhaust off and seat out will do it, but it just takes away from working harder at a goal.
I should see better air here too which will help and just need the track to work well again.
I am going to get my limiters on and hope to hook well, keep the front end down. The window switch at ON @ 4100 leaves some ET still on the table.
The video I kept pausing and going frame for frame today and the front tires hit ground just after the 60ft on the 10.05 / 1.34 60ft pass.
Old Nov 2, 2009 | 07:10 PM
flyinZ's Avatar
Atta boy! Keep workin' at it, you'll get it for sure If I was as close as you, there would be NO question, Id try it again before the end of the season, lol.
Dang, I weighed my car yesterday at the seed house, with no driver its @ 3475lbs...damn pig..I think it needs a diet this winter.
Old Nov 2, 2009 | 07:19 PM
LS1 SPEED's Avatar
yeh... time get limited at the end of the year trying to tidy up around the house, grab that good track air too + make sure time is not neglected with the fam.
was not too worried about going, but I have thought about it all day and said I have to go back out
