comp 987 springs...MAX LIFT?
you've got installed height and coil bind numbers... shouldnt be too hard to figure out. but you wont be able to get those springs in a 1.8. id say 550 lift max. you cant run much lobe intensity with those heavy springs and that spring rate. run 1518s or if you dont care about spring quality... the patriot gold ****
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Experience... 355 LT1 with 503cam with beahives eyelashed every piston and killed the valve seats on the Lloyd Elliot heads only spinning it to 6500. Same motor is now running a GM847 with Patriot Golds with no problems and hit's 7000 regularly!
/story
Patriot Gold's > Pac 1518's
On the spring pressure side note, if you have a set of springs that have un-equal spring pressures within a set then you have a bad set of springs and need to contact the manufacture. I tested every one of mine (although LS1 based) and they all after 15k miles were still within spec and near identical across the set.
