maybe some future mods
Old Nov 9, 2009 | 02:57 PM
mattgt40's Avatar
Default maybe some future mods
with the mods in my sig plus a B&M 2400 stall,pace setter headers,Jegs H-pipe & 2 flowmaster super 44 mufflers dumper before the axle what should i be running in the 1/4 mile
Old Nov 9, 2009 | 03:03 PM
Wicked94Z's Avatar
get a real stall... yank, edge or something
Old Nov 9, 2009 | 03:15 PM
96lt1m6's Avatar
I tottally agree with the above +1 more thing, get that hypercrap tune out of that PCM send PCM to madtuner,pcm4less etc. you will show true improvement!
Old Nov 9, 2009 | 03:18 PM
96blackta's Avatar
I don't understand mail order tunes... it's like telling your doctor what's wrong with you over the phone and hoping he makes a correct diagnosis and sends you the right stuff.
Old Nov 9, 2009 | 03:29 PM
Wicked94Z's Avatar
no because *most* of the tunes are based on a dyno tune of a similar setup.
Old Nov 9, 2009 | 03:35 PM
PewterScreaminMach's Avatar
Bottom 13s without issue at an average track, average day, full weight car. That's what I'd expect, anyways. And keep in mind "average" everything in a full weight car. Clearly it has 12-second potential in the right conditions, especially with some weight reduction.
Old Nov 9, 2009 | 03:42 PM
BSmiff's Avatar
Agreed. Get a Nice 3000-4000 stall converter from a reputable company and get it tuned by mail or on a dyno I would say mail order personally. Then from there just hope for good conditions.
Old Nov 9, 2009 | 03:45 PM
96blackta's Avatar
But an actual dyno tune is still better.
Old Nov 9, 2009 | 03:57 PM
HottestZ28's Avatar
depends on what you call better...peak numbers are just numbers i like to get best of both worlds driveability/power
Old Nov 9, 2009 | 04:01 PM
Wicked94Z's Avatar
no ****??? you have boltons... you'd see very little gain over a mail order tune, probably not worth the cost of a dyno tune. end of story.
Old Nov 10, 2009 | 09:46 AM
tbag_skywalker's Avatar
A dynotune would give you give you much better driveability/power than a hypertech programmer, and so would a mail order tune, although not quite as accurate.
Heck, you could plug a Gameboy into your PCM and get a better tune than using a hypertech programmer.
I believe that's what we're tryin to say here.
Old Nov 10, 2009 | 01:20 PM
SPEED#1's Avatar
Mailorders work just fine for a bolt on car and **** even some bigger 383s are using them and it works great. You can make more power with a dynotune and atleast get a print out of what you have. But a mailorder will do the same thing and if not better sometimes. They have files of what works with what setups and send it over to you and its cheaper.
