My winter build thread w/ pics
Always great to see pics of builds, I regret not taking any during my build.
Good luck with the build buddy, hope it all goes well and you achieve the goals you have set ahead of you!
Im taking pictures this time because when I did my 355 build I took very few pictures.
I didn't want to start the two projects at once, but since I wanted to use the heads and cam that were on the camaro in the firebird, I really didnt have a choice.
Tonight Ill be putting the cam and gaskets in the engine for the firebird. Ill take some pictures and post later tonight!
Here are some pictures
Also, want to extend that to a Spring/early summer project and work on my Trans Am for dirt cheap?
Doing everything in my sig for spring.. cam setup is possible.. but not likely considering I don't work much while I'm up in Ames for college.
So if you want to do a opti, plugs, wires, LT's, ory, EWP, and fixing my oil leaks with Dave (not the rear-main), feel free to help a retard out and do so!
I wish I had 1/4 of the patience to work on cars and 1/4 of the knowledge too
The mods will be:
Hotcam with stock rockers
Heads milled .025 with a good valve job
B&M ripper shifter
4.10 gears
hooker cat back
I am from Grinnell, Central IA
Last Night I put the engine back together, Set it in the K-frame and Hooked the wiring back up.
We got the motor completely in, his hooker cat back started.. The complete interior in. It kinda slowed down after you guys left.. I still havnt been to bed yet...
pics!
Other then that I worked my *** off on it and couldve had it running today if I didnt have a family get-together.
