My winter build thread w/ pics
Old Nov 29, 2009 | 07:58 PM
  #41
mattcossel29's Avatar
lol hes got a circle d 3600 and an flt trans in his 96 z
Old Nov 29, 2009 | 08:24 PM
  #42
94LTZ's Avatar
He knows he wants two built auto with stalls lol jk
Old Dec 9, 2009 | 06:32 PM
  #43
355z28's Avatar
Just an Update on this. Last saturday I did get it running. It runs great, but i had to use a bump start to get it going due to the VATS being on. Theres no reason for it to be on because the steering column, all wiring and modules were transferred over to the other car. The only module I didnt transfer was the door harness and keyless module out of the passenger side.
Either way I'll send the computer off have the Vats deleted and a mailorder tune for the car. All I have left with it is to swap rearends and find a cheap center console and boot! Ill try to get a Video up here soon.
Old Dec 29, 2009 | 08:59 PM
  #44
355z28's Avatar
Heres the progress on my Camaro, I finished the intake manifold, and got most of the engine bay finished. It needs to have a few touch ups on it but Im pretty happy with it.
Old Dec 29, 2009 | 09:55 PM
  #45
snk-huntr's Avatar
That's a good winter project, let us know how it works out in the spring.
Old Dec 29, 2009 | 11:22 PM
  #46
marc97taws6's Avatar
The Camaro looks very clean Austin! It has came together very well
Old Dec 29, 2009 | 11:41 PM
  #47
robsquikz28's Avatar
Lookin good, what paint did you use on the intake and engine bay?
Old Dec 30, 2009 | 07:26 AM
  #48
355z28's Avatar
Thanks guys.
Rob the paint is duplicolor Acrylic Enamel. I cleaned it with super clean, then used a rough stripping pad, wiped it all down with wax and grease remover. I applied a light coat and let it tack up then a couple very heavy coats to make it lay out flat and have a smooth finish.
Old Jan 15, 2010 | 11:01 PM
  #49
Alright here are some pics from tonight and a little exhaust vid!
http://www.youtube.com/watch?v=tFoy31vYKwA
Old Jan 15, 2010 | 11:28 PM
  #50
Man, excuse the interior pic.. The interior looks great in person but the flash makes it look really bad..
Old Jan 16, 2010 | 12:24 AM
  #51
355z28's Avatar
wow that interior pic makes it look horrible
The car hasnt been cleaned, or buffed or waxed for several years. I wish I had pictures when I picked it up. It literally had moss growing on it.
Since its winter, and the car was built for daily driving I probably wont be touching it to much (cleaning wise) except for a few rinses here and there til spring.
It is still untuned, and has the stock v6 rear in it. the 3.23s are miserable to drive with, and I cant wait to put my 4.10 rear under it.
Old Feb 23, 2010 | 07:38 PM
  #52
355z28's Avatar
UPDATE:
Instead of putting the LE2 H/C on my 355 I decided I wanted to build another engine for the car.
I ordered a 383 rotating assembly from Corey at Clayton Racing that consists of:
Compstar forged rods
Compstar forged Crank
CP forged Flat tops with 2 valve reliefs
The block is at a Local Machine shop waiting for the rotating assembly to be finished up:
.030
4 bolt splayed cabs
Half Filled with hardblok
12.4:1 compression
LE2 heads
236/244 cam on a 112.
For this engine. Ill be running .026 MRG head gaskets. The machine shop and I decided to run the pistons .012 in the hole instead of zero decking. This gives me an option to change pistons down the road if I decide to do anything different.
Its built around nitrous, Unfortunatly I dont have the money to spare for the kit this year. The plan is to see low elevens on motor.
I'll post pictures of the internals when they come in!
Old Feb 23, 2010 | 10:53 PM
  #53
LT1's Avatar
LT1
Sweet bird! i been thinking of doing something like this with my 97 Firebird V6, I want to put a LS1 or LT1 still unsure.
Heres' a pic of it.
Old Feb 23, 2010 | 11:13 PM
  #54
Speed Density's Avatar
hashtagBMW
Good job!
Tony.
Old Feb 24, 2010 | 06:35 AM
  #55
MTBSully's Avatar
great thread. lots of hard work put in here.
Also on another note, ive noticed this a few times in the past on people builds but what exactly is "half filling" when talking about a block. Heard it a million times but never actually knew what it meant. Sorry to hijack.
Old Feb 24, 2010 | 06:57 AM
  #56
355z28's Avatar
Its a Block filler, basically you fill the block half way (to the bottom of the frost plugs) to add additional strength in the engine.
http://www.hardblok.com/
Tony are you going to make the shootout? or are you still parting your setup?
LT1 thats a clean looking bird! The swap was pretty simple, but a lot of work. I dont think I would ever attempt it without a Donor car!
Thanks guys, its been a long time coming. And Im hoping to here the Camaro fireup within the next month or so!
Old Feb 24, 2010 | 07:33 AM
  #57
MTBSully's Avatar
okay so that helps a little. But how is the motor supposed to stay cool if the water jackets are filled with cement (more or less haha)
Old Feb 24, 2010 | 07:42 AM
  #58
355z28's Avatar
I was worried about the same thing, but after talking to the builder, and doing lots of research it seems that being half filled causes no heating issues on street cars.
There's actually a thread that was started not to long ago on it. Its probably 2-3 pages back. I wanted to do it just because of the ammount of nitrous it is capable of handling now.
Old Feb 24, 2010 | 09:14 AM
  #59
fastfox's Avatar
Good luck with both of your builds looks good.
Old Mar 1, 2010 | 05:09 PM
  #60
Where is the pics of the rotating assembly!
