Help with installing new elbow. Update again! I got it on!
Old 11-21-2009, 10:20 PM
airfix's Avatar
Pretty obvious since you've tried many things to get it on and you still havnt gotten it on. Sucks that ppl sell just that doesnt work but you get what you pay for. Ive been there with a similar elbow off ebay but I was able to get it on.
Old 11-22-2009, 12:12 AM
1993 z28 f1's Avatar
Hey:
Go to Lowes , Home Depot, or Menards and get a Fernco rubber water pipe connector used to join two black plastic pipes together. Thats what I did the one that came with one kit was so flimsy and tight it was just easier.
$10-12, then your done. Heat it up however is best for you and lube with dish washing detergent, not to much, just enough to help it slip on and use some heat resistant gloves and put it on while still very warm/hot. I hope its not too cold out as it will harden up quick. Use a heat gun on it outside if its cold somewhere up North. Be careful not to overheat it. Good Luck
Dub
When In Doubt Do Without
Attached Thumbnails Help with installing new elbow. Update again! I got it on!-dsc00491web.jpg
Old 11-22-2009, 09:15 PM
MasterTomos's Avatar
it shouldnt be that hard to put on, somethings wrong-probably just the size. That's what you get for cutting corners and buyin ebay crap!!! haha jk man. do you have an aftermarket throttle body or something maybe?
Old 11-22-2009, 10:30 PM
Endersshadow's Avatar
Not as far as I know. The car is supposed to be stock.
Old 11-23-2009, 04:12 PM
Originally Posted by 1993 z28 f1
Hey:
Dub
Holy ****! Thank you so much. I finally got the damn thing on. Your suggestion worked perfectly. Here's a picture! Woo hoo!
Once again...thank you and thank you to everyone who offered a suggestion.
Old 11-23-2009, 04:38 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
LS1Tech 10 Year
I would have been interested in seeing pics of the parts that would not fit. Would the adapter supplied by the seller even fit onto the elbow itself?
Old 11-23-2009, 04:47 PM
I could get it on the elbow if I struggled with it for a while.....but getting it on the elbow and the throttle body just seemed impossible.
Old 03-19-2010, 04:38 AM
Reaper-Z's Avatar
I know this is a dead thread but did you have problems putting the sensor in the side? What about the vacuum tube for the opti? I have the same ebay elbow but haven't installed it yet.
Quick Reply: Help with installing new elbow. Update again! I got it on!
