Vented or Non-Vented??
Old Dec 4, 2009 | 09:01 AM
GoFastKid's Avatar
Default Vented or Non-Vented??
It's time for a opti swap in my z28...do I need a vented opti or a non-vented? Or does it even matter? Thanks
Old Dec 4, 2009 | 09:21 AM
monster81's Avatar
vented for sure,
Old Dec 4, 2009 | 10:39 AM
shbox's Avatar
Yes, it matters. Your 1995 Z would be vented.
Old Dec 4, 2009 | 10:45 AM
GoFastKid's Avatar
I should have been more specific, I also own a 94 T/A LT1 which is the one I am doing the swap on..is that one vented shbox?
Old Dec 4, 2009 | 10:47 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Unless something has been modified, 94's are not vented.
Old Dec 4, 2009 | 10:51 AM
the_merv's Avatar
Veteran: Air Force
The 1994 isn't vented so if you want to go vented you will need the 1995 Timing Cover and lengthen the Cam Dowell Pin a lil bit.
Have fun.
Old Dec 4, 2009 | 11:04 AM
JAKEJR's Avatar
One other option is to modify a NON-Vented Opti to a Vented Opti. One of the mags I have around here shows how to do it.
Depending on how good you are working with your hands, amount of time you have, availability of the cover you'd need to replace, etc., it might be worth considering.
I can track down the mag article if you need me to; could be posted on their website. Let me know.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Dec 4, 2009 | 11:33 AM
pillarpod's Avatar
Have fun.
Old Dec 4, 2009 | 11:41 AM
MasterTomos's Avatar
92-94 Lt1's non vented
95-97 Lt1's vented
Old Dec 4, 2009 | 11:44 AM
psiconversion's Avatar
LS1Tech Sponsor
except on b-body's. ALL B-Body's were vented. And dont ask me why : )
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old Dec 4, 2009 | 11:48 AM
JAKEJR's Avatar
Huh?
Jake
Old Dec 4, 2009 | 12:02 PM
96capricemgr's Avatar
All the b-bodies were indeed vented, Up until two weeks ago I owned one of each year the LT1 was available too so don't argue with me.
For those of you with unvented setups all you have to do is buy the MSD cap and rotor kit and it will add a vent. Whole lot easier than swapping timing covers and I am sure a whole lot better than whatever a magazine advocates.
Old Dec 4, 2009 | 12:17 PM
robsquikz28's Avatar
IF you need the timing cover for a 95 I have one I can sell ya! Or I have a excellent oem non vented opti from a 94 that has less than 2k miles on it! Whichever you want lmk.
Old Dec 4, 2009 | 12:47 PM
shbox's Avatar
Yeah, it helps to know what it is you are working on. Everyone else came to the rescue.
Old Dec 4, 2009 | 06:28 PM
I was just talking about the aluminum head LT1's...I usually forget about the B-Bodies
Old Dec 4, 2009 | 08:42 PM
Badazz 97 TA's Avatar
You will also need to change the cam timing chain sprocket. the hole in the middle is different. if you are gonna do the swap get the 95 f-body timing cover. Or you can do what 96caprice said and just get the MSD cap
Old Dec 4, 2009 | 09:45 PM
shbox's Avatar
You would have to change the whole cam too, if it is still stock. The hole in the front of the early stock cams is not big enough for the vented opti drive.
Old Dec 4, 2009 | 11:18 PM
SPEED#1's Avatar
I have a 95 timing cover for sale if you want it?
Old Dec 5, 2009 | 08:47 AM
yup i know. Everyone else is giving vague info in this thread so i thought i would join in and only give partial info also.
Old Dec 5, 2009 | 10:05 AM
shbox's Avatar
LOL, then you did and excellent job.
