tires
Old Dec 4, 2009 | 01:36 PM
killamike's Avatar
Default tires
Hey back at it again. next question is tires. i got new front tires there 17's. the backs are 18's 275/35's. So ive looked around and they are a pretty penny what are some of my options? could i go smaller with more tread. not the smartest on this subject but i know the 2nd number is how much percent the actual tallnes. i dk if im maken sense so thats y i am askin...thanks in advanced.
Old Dec 4, 2009 | 02:04 PM
chavez885's Avatar
So they are 275/35/18's....?
Old Dec 4, 2009 | 02:23 PM
slomarao's Avatar
If your going to bother to mod your car for it to be faster, handle better, stop quicker tires are the contact between the car and pavement. A real nice set will help the car with traction(better 60fts, even on the streets). Also with handling, the better tire you put on the better the car will do in the corners. Braking applies the same.
Dont skimp out and buy something cheap, its wasting all the money you spend on headers,gears, CAI, etc.
Old Dec 4, 2009 | 03:34 PM
killamike's Avatar
yes there 275/35/18. i do plan gettin some mods startin out with exhaust. so should i stick with what size that are on the. i plan on spendin over 5-6 hundred for the pair
Old Dec 4, 2009 | 03:36 PM
killamike's Avatar
or unless u could point me in the right direation. sry fer the dble post
Old Dec 4, 2009 | 03:50 PM
koolaid_kid's Avatar
I think you are asking if you can go wider than 275 (current width) and with a lower profile (currently 35). In order to determine that, you need to know the rim width of the wheels you have. The wheels and tire section of this forum would be an excellent source to figure that out.
AFA a tire source (not sure if you are asking that) www.tirerack.com is a sponsor and has pretty good prices, from 160 and up per tire for your current tire size.
Old Dec 4, 2009 | 03:58 PM
killamike's Avatar
that helps thanxs. i guess im just askin ur guys opinion.. im not sure wat width my tire is i wana say 10in? that couldnt be right? i guess thats y im here askin.
Old Dec 4, 2009 | 06:44 PM
Your tire width is 275 millimeters, which works out to 10.8 inches.
