Quick Question....
Old Dec 12, 2009 | 05:38 PM
1 Craz28's Avatar
Default Quick Question....
Is it normal to run your engine for about five minutes and have the cat turn blaze orange?
Old Dec 12, 2009 | 07:06 PM
Z-RATED94's Avatar
It's not uncommon for a cat to start coming apart on the inside and become plugged up. That might be your problem.
Old Dec 12, 2009 | 07:18 PM
Randal McSandal's Avatar
^ Most def. I'd either get rid of it, or change it out..soon.
Old Dec 12, 2009 | 07:39 PM
RamAir95TA's Avatar
Not normal. That's usually indicative of a clogged/plugged cat. Very dangerous.
Old Dec 12, 2009 | 07:46 PM
1 Craz28's Avatar
It's brand new. I started it for the first time today. It's a three hundred dollar Random high flow. Is it running too rich then? Or is it running too lean and too much O2?
Old Dec 12, 2009 | 07:53 PM
1 Craz28's Avatar
Never mind, I think I may have left one O2 sensor unhooked!!! AARRRRRRRGGGGGG!!!!
O'wait, it IS hooked up, I was retraicing my cat "Y" install and only installed one O2 but remembered the other O2 is on the header not the "Y".......Back to my previous question. Too rich or too lean?
Old Dec 12, 2009 | 08:14 PM
Smoke Em's Avatar
i dont think running lean or rich is gonna make the cat glow red. your 100% positive that its not clogged, if it is your gonna have alot more problems if you dont fix it fast
Old Dec 12, 2009 | 08:25 PM
1 Craz28's Avatar
It's brand new! Clogged with what? Corn syrup!
Just forget I even posted, I know your not going to help because you want me to @#$% something up so I buy more @#$ for christmas! And then your sitting there chuckling, hehehe, he's running rich because his tuner told him to buy freakin 36lb injectors for stock heads and shortblock and burnt him a chip without even datalogging.................................
