Fuel Pouring Out Of Coolant Crossover Tube!!!!
Old 12-19-2009, 10:46 PM
  #41
draggin97s10's Avatar
nice add yes agreed
Old 12-20-2009, 11:37 AM
  #42
SmartOJ's Avatar
ttt...
Old 12-20-2009, 12:49 PM
  #43
AChotrod's Avatar
Originally Posted by draggin97s10
ok you can test your coil if you can find the ohm reading it should be at when its operating correctly..kinda of need mitchell or a GM write up... now an opti is really the same as any distributor but flat and thin if you want pull yours apart youll need an inverted torques bit i think 6 or 8 in size of the points in side are worn out then you need a cap and rotor as for ohm reading on coil i have no idea
the bolts that hold on the TB cover on will work if you flip one upside down. Might risk ruining the threads though.
Old 12-21-2009, 07:10 PM
  #44
SmartOJ's Avatar
Problem Fixed!!!!!!!!!!!!!!!
Got a buddy to put a scanner on it and Engine Coolant Temp sensor was reading -40F yes negative 40 degrees. so the computer was dumping gas in. replaced it and now im firing everytime.i cant believe a $11 sensor been causing me so much headache.i still have a few issues to work out but at least i can start it to troubleshoot it now.
Thanks guys to all those who helped!!!!!
Old 12-21-2009, 07:23 PM
  #45
RamAir95TA's Avatar
This is a good reason why a simple ALDL cable and a laptop is a priceless diagnostic tool for OBDI cars.
Old 12-21-2009, 08:03 PM
  #46
SmartOJ's Avatar
arent the scan programs for the laptop more expensive than a handheld scanner itself? i cant c myself spending 4 or 500 for a tool i wont use that much
Old 12-21-2009, 08:13 PM
  #47
RamAir95TA's Avatar
$125 for a cable, and the software is free.
www.ttspowersystems.com
Quick Reply: Fuel Pouring Out Of Coolant Crossover Tube!!!!
