Afr 235
Old Dec 17, 2009 | 06:23 PM
draggin97s10's Avatar
Default Afr 235
is anyone running these on an LT1 if so with what intake and fuel setup. any numbers? or does any1 have these on a gen1 in a late fbody?
Old Dec 17, 2009 | 07:18 PM
Tony Shepherd's Avatar
I just purchased a set with the comp CNC package. I think I will be the first to have them on a LT1. Should be up and running in about 4-6 weeks hopefully. Intake will be a Super Vic. converted for EFI.
These heads flow 340 cfm and mid lift numbers are insane! You better have large cubes and plan to spin it high for these to work.
Old Dec 17, 2009 | 07:47 PM
oh im just trying to fill my brain with knowlege. im running LE2 236/242 612/612 on 111lsa. with LE2 heads 383 full supporting mods. BUTTTTT My father and i are building a new small block for the jet boat and i was thinking of going injected and i have another LT1 if your getting what im saying would be stupid. Its got a bigblock in it now. lots of power but heavy.
Old Dec 17, 2009 | 08:35 PM
86formula's Avatar
dont mean to hijack but what kind of numbers are you putting down with your current setup? (LE2 heads motor)
Old Dec 17, 2009 | 09:16 PM
just got done with build. driven it running good for about 10 minutes and its pretty stupid ill update when dynod
Old Dec 18, 2009 | 01:59 AM
chavez885's Avatar
An LT1 in the water? what the hell!! lol
Old Dec 18, 2009 | 09:16 AM
1redta's Avatar
lots of the mastercrafts after 94 I believe were lt1 motors. to get around the opti problems it used an northstar ignition.
Old Dec 18, 2009 | 10:41 AM
raymond mckinney's Avatar
I've been waiting to see some numbers and track times out of these.
Old Dec 18, 2009 | 12:27 PM
I8ASaleen's Avatar
I was loling at the LT1 in the water comment. It's just like 'jumbo-shrimp' - total oxymoron.
Old Dec 18, 2009 | 03:36 PM
James Montigny's Avatar
I was reading about those in a performance mag earlier this month, I'm very anxious to see what they do on an LT1.
Old Dec 19, 2009 | 11:20 AM
yes me aswell and yes an LT1 396 with these heads in the water in a 15 foot jet boat. and i would convert ignition to LS1. the boat would weigh like 4hundred pounds less with this set up as opposed to the BB 402 in it now. Its already scary now.... just weight ill get some pics up
Old Dec 19, 2009 | 05:21 PM
Z-RATED94's Avatar
In a 15ft. boat? That's gotta be a rush. I'm not familar with jet drives, do you have a rpm limit like an outdrive?
Old Dec 19, 2009 | 05:47 PM
well no but you want and extremely flat torque curve. your rpms are only limited by your pump and bowl type. Ive got a b type impelar i really dont need crazy rpms. i really likes these heads they have awsome midrange flow which would be sweet.
Old Dec 19, 2009 | 05:53 PM
mdacton's Avatar
joe sherman built an engine with these about a year ago think it was in hot rod mag.
Have seen other results with them too..... all I can say is they are bad ***. Wish I had a set.
But dont get too cought up on flow num,bers and big CC running that head on alot of stuff would slow it down. I feel its a more race oriented head.
Old Dec 19, 2009 | 08:24 PM
well you see the great midrange numbers with a good cam grind would equal anwsome torque horspower combo..
Old Dec 20, 2009 | 08:19 AM
88BlackZ-51's Avatar
I dont recall AFR making a 235 for an LT1. The biggest is a 227cc head that flows in the 33x cfm range.
Old Dec 20, 2009 | 08:28 AM
The 227 flows in the 32x range and yes that is the largest head they make for LT1. However....you can get a 235 and convert it to fit a LT1. People take Dart and Brodix SBC heads all the time and convert them to fit LT1's. I do think AFR will eventually make them for the LT1.
Old Dec 20, 2009 | 12:54 PM
96redcamaro's Avatar
I have been throwing around the idea of a new top end in my head. I would also like to see some numbers on these heads. When you say spin it high. How high are you talking about?
Old Dec 20, 2009 | 01:39 PM
speedracer2536's Avatar
7k plus
Old Dec 20, 2009 | 02:54 PM
Originally Posted by speedracer2536
7k plus
8k plus.
