What could cause this.....BOOM!
Old Dec 19, 2009 | 12:17 PM
Rumblin70ss's Avatar
Default What could cause this.....BOOM!
Car has 40k on it. Rarely ever ran hard. Hard to see, but the piston is gone and there is a hole in the block on the left hand side. Cylinder #2. Parts of the piston were found in the throttle body and the other cylinders if you can believe that.
Car was going up a slight incline and was turning no more than 2500 rpm when it let go. I just don't get it.
Thanks!
Tony
Old Dec 19, 2009 | 12:25 PM
Rick804's Avatar
Did you have it in sixth gear while doing only 25 mph?
Old Dec 19, 2009 | 12:31 PM
It's an auto and I was probably in 3rd IIRC.............
Old Dec 19, 2009 | 12:38 PM
Never sprayed and I have owned the car since 1996 with 7k miles. Car has been ran at the track about a dozen times in the past 13 years.
Old Dec 19, 2009 | 12:44 PM
94Firehawk161's Avatar
Was it overheated at some point?
Old Dec 19, 2009 | 12:50 PM
Not in the time that I owned it and that was most of its life!
Old Dec 19, 2009 | 01:17 PM
sepno77's Avatar
Do you have any enemies? Maybe someone sabotaged your ride by sticking a small screw or something of the sort in the intake.
Old Dec 19, 2009 | 01:23 PM
LOL......no enemies and the car is locked up all the time.
Old Dec 19, 2009 | 01:25 PM
ScrapSilicon's Avatar
Originally Posted by Rumblin70ss
383 with Callies/Oliver/JE parts!
damn ..the build needs fast trackin' now
Old Dec 19, 2009 | 01:28 PM
sepno77's Avatar
Well the only other thing I could think of is that dam swine flue got to your car.
Old Dec 19, 2009 | 01:42 PM
I don't play games.....LOL.
Better than me getting it!
Build it bigger, stronger, faster and better!
Old Dec 19, 2009 | 05:26 PM
Z-RATED94's Avatar
Could have been a factory flaw in the piston, who knows? I like your choice of rods. How much, if you don't mind me asking?
Old Dec 19, 2009 | 05:35 PM
C5042081's Avatar
looks like something let loose, did the valves on that side look good?
Old Dec 19, 2009 | 05:45 PM
wrd1972's Avatar
How could that cause this problem?
Old Dec 19, 2009 | 06:34 PM
I think they were around $1100.00 IIRC...........
I don't have pictures, but I was told the heads were damaged but repairable.......piston parts were everywhere including all the cylinders and in the rubber boot in front of the throttle body.
Old Dec 19, 2009 | 06:52 PM
x Wild Bill x's Avatar
Funny, I sorta had the same thing happen to me... I had my power steering pump squeaking so I put it up on ramps to replace, messed up a pressure line and had to wait 5 days. Installed everything and went to start it and pound pound pound... my #8 piston was introducing itself to my head and valves... Car had 90k miles, had an LE1 heads/cam and ran perfectly till then. Tell you what, that sucked! So I feel your pain. I went cheaper then you and got a short block and rebuilt it.
Good luck!
Bill
Old Dec 19, 2009 | 08:07 PM
robsquikz28's Avatar
Wow never heard of that at all and have no idea what caused that maybe it lost oil pressure before it let go and/or blew a head gasket and sucked in coolant and hydrolocked the engine????
Old Dec 20, 2009 | 07:14 AM
Good luck!
Bill
Thanks man! I almost went that route, but I didn't want to have another car in pieces for awhile. Even if it didn't run, I had all the parts in one place. Glad I didn't pull it anyway as the hole in the block would have stopped me in my tracks!
At this point its anyones guess.......just bad luck to a point but at least I'll have a fast car out of all this!
Old Dec 20, 2009 | 09:41 AM
96capricemgr's Avatar
Is the mod list in your sig complete??
Did you verify the timing of the MSD opti was zero?
One particular popular tuner likes to break pistons with too much timing and too little fuel. If you never verified timing of the MSD it could have been advanced and lead to massive detonation too.
Old Dec 20, 2009 | 12:45 PM
The mod list is complete and I'm pretty sure I verified the timing when I put the MSD in.
I would think I'd hear the detonation to be honest. Also it appeared that only one cylinder had an issue. If it were detonation, I would think I would have seen something in all the cylinders.
