Operation Engine Bay of Pigs
Old Jan 12, 2010 | 01:57 PM
  #41
skinnies's Avatar
Originally Posted by robsquikz28
2-wtf are there 3 vac. ports in the back of the intake for??
He took this from my idea I did on my formula a few years ago, it's so you can plug the vacuum ports on the side of the intake and run all the vacuum lines(including the map) at the rear of the car so it's much CLEANER looking than having vacuum lines ran off the side of the intake.
Old Jan 12, 2010 | 02:58 PM
  #42
Torque Fiend's Avatar
yes sir. I love skinnies (no homo) for that. He's been very helpful.
Old Jan 12, 2010 | 05:17 PM
  #43
Looking better everyday....but answer these questions?
1-why did you paint the fuel rails black?
Look at this, tell me it's not sick. Again, the IM is not finished. Also, I didn't polish them because I'm not that big on polish and bling everywhere. Only subtle polished stuff here and there.
Plugged up the two on the passenger side and one on the driver. Deleting evap so I don't need it on the left. Moved to back that'll serve the relocated MAP sensor, it will no longer be in the stock spot. The two on the passenger side go to the back, they lead to the HVAC and the fuel pressure regulator.
3-can we get a close up pic of where you deleted your fuel lines and made the block off plate?
Inside of wheel well view
Block off plate for the old fuel lines I assume you were asking for.
Pics after clear coat:
Old Jan 12, 2010 | 07:01 PM
  #44
snk-huntr's Avatar
looking good minus the fuel rails ,I think they look way better polished.
Old Jan 12, 2010 | 08:37 PM
  #45
scj's Avatar
scj
i think the intake mani and fuel rails would look good if the fins on the mani were polished or at least brushed.
Old Jan 12, 2010 | 08:44 PM
  #46
they fins will be, the IM is not finished.
Old Jan 20, 2010 | 10:51 PM
  #47
worthless update of the day
1-20-2010
Went to finally install the heads as I gave the engine bay a week to cure and give me a break.
Had a huge hiccup when I tried to remove the passenger head temp sender unit plug and fucked it up. You need a square 5/16 drive to take it off, but I don't have that tool. I tried creating a tool by grinding an allen wrench into a square wrench, but it wouldn't come off. Heated w/ a torch and warped it. I'm ******* pissed. I'll work on it tomorrow w/ my dad.
Intake pretty much finished:
Old Jan 20, 2010 | 10:53 PM
  #48
SoxXpupPeT's Avatar
the black fuel rails look good. definitely different thats for sure. everyone just polishes them... me included lol
Old Jan 20, 2010 | 11:02 PM
  #49
thanks.
Yeah, everyone has them polished and they just don't really do it for me that way.
Old Jan 20, 2010 | 11:43 PM
  #50
Speed Density's Avatar
hashtagBMW
This is a great thread, lots of fancy stuff to look at. Keep it up
Old Jan 20, 2010 | 11:48 PM
  #51
robsquikz28's Avatar
Lookin good buddy and how does the map sensor bolt in now? pics?
  #52
thanks. I wish I had the money for your z06. That's a nice price.
Old Jan 20, 2010 | 11:52 PM
  #53
Yeah from the previous discussion w/ 'skinnies' notice I deleted the map sensor vacuum mounting hole on the intake.
I don't have the map sensor figured out yet. But what I'm thinking is get an L bracket and drill some holes. Use the same threads coming off of the egr and bolt the bracket down. Then mount the map sensor there. I think it'll work and be hard to see, but we'll have to see.
Old Jan 21, 2010 | 12:28 AM
  #54
BSmiff's Avatar
Looks good boss.
Old Jan 21, 2010 | 12:49 AM
  #55
iceman15's Avatar
man this thread is exciting! keep up the great work man!
Old Jan 21, 2010 | 01:56 AM
  #56
MasterTomos's Avatar
love the intake/rails man...good work
Old Jan 21, 2010 | 02:37 AM
  #57
94maro's Avatar
1-20-2010
i think the fuel rais are sick black...the only thing i disagree on is the top of the intake lins instead of sanding them downa nd polishing like u did i would recrementd paint those black to and i think it would make it pop..my 2 cents
Old Jan 21, 2010 | 07:48 AM
  #58
i've seen some manifolds with the black fins on red and it is not the best looking to me.
Old Jan 21, 2010 | 09:55 AM
  #59
baylove's Avatar
Originally Posted by pillarpod
that Aircraft Paint Stripper is the **** i love it
yes sir i like it too makes things alot easier
Old Jan 21, 2010 | 10:00 AM
  #60
baylove's Avatar
man your doing a really good job i wish i could all the things your doing to your car little details make a real big difference i will keep up with this thread i like it good job once again
