EVAP charcoal canister removal
So i basically just have to pull it out, or will it slide out? if anyones got any pictures with more detail it'll help a lot.
I'm going to replace it just cause i have to pass inspection so i can't break the bracket.
hey fire-chickens,
If you haven't bought a new one yet, I can sell you mine, along w/ all the evap stuff (minus vac lines)
My canister and purse solenoid (side of the intake manifold, in case I messed the name up) are pretty damn new from the factory and only have some 700 miles of usage.
PM me.
I suggest you use the flat head screw driver to undo that strap.
or move the ends apart from each other vertically, while using the screwdriver.
PM me.
What about the parts on the intake? I've got a small-square looking part, on the passenger side of the intake. Im guessing thats the solenoid...What do I do with all that stuff, far as removal goes? I'd like to get rid of that crap myself.
Pull your skirt up and yank all that trash out of the Wheel Well..it's all pretty much junk.
Remove all the Lines and Solenoid, clip the Connector if you want, and cap the one port off that is on the Intake that it gets the Vacuum from. Cut the plastic EVAP Line that runs with the Fuel Lines and stuff it in the Wheel Well.
I'm curious to this whole process as well. Not to try an hijack the thread but, I'm getting ready to throw on some LTs and would like to clean up the engine bay as much as possible. I've already ordered the EGR delete and will be loosing the AIR system, I will also will be getting the ABS delete kit soon. If I can get rid of the EVAP stuff I might be able to see an engine under all those hoses and vacuum lines finally.
I removed everything under my hood that has to do with emissions and pretty much most of my vacumm lines that deal with or around the a/c and heat components. All of that's gone as well. Am I good to remove the EVAP **** in the rear. Not sure I'm following this whole drilling a hole in the fuel cap thing though. Am I using this at all or can it go to eliminate weight?????
So am I understanding right, if you want to loose it all you can just buy a vented gas cap? The gas door isn't near air-tight so I would imagine any vapors would just escape there? If you went that route could you drop the cannister in the rear and everything going up to the engine from the fuel tank aside from the fuel lines?
Like I said before I would just like to remove as much clutter as I can so I can find that engine finally.
If it is a one way valve (in only), how do you allow the tank to bleed off excess pressure? Is there another vent?
Na I dont have anything like that..I pulled my Panel, looked at the Sending Unit..capped the EVAP, and ran a straight line from the Vent Line down the side of the Tank where the Factory one pretty much was..it's just a vent from what I could tell.
It doesnt build up pressure and hasn't blown up yet so I think it's good.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
