View Poll Results: Pan Leaks Yes or No
My Canton Pan Leaks
0
0%
My Canton Pan Sealed Fine
3
75.00%
My Moroso Pan Leaks
1
25.00%
My Moroso Pan Sealed Fine
0
0%
Voters: 4. You may not vote on this poll
Oil Pan ???'s
Old Jan 5, 2010 | 12:33 PM
djjab57's Avatar
Question Oil Pan ???'s
Ive heard some horror stories of SOME people getting there Cantons to stop leaking, Is the Moroso any better ? I know its only a 5.5 over the Cantons 7 quart, Also is using a stud kit on the pans better for sealing it up over the stock bolts ?
Old Jan 5, 2010 | 02:13 PM
LadyDriven's Avatar
My Moroso leaks like you wouldn't believe
Old Jan 5, 2010 | 02:24 PM
djjab57's Avatar
well that sucks, i really want a aftermarket one but they all seem not to seal to great
Old Jan 5, 2010 | 02:50 PM
RamAir95TA's Avatar
Just because you have an oil leak doesn't necessarily mean it's the pan's fault. Gasket choice, fitment, block, timing cover, etc., all play a role in keeping the oil where it's supposed to be.
Old Jan 5, 2010 | 02:54 PM
djjab57's Avatar
Is the stud kit better than the stock bolts ? im going to try the canton i believe
Old Jan 5, 2010 | 02:56 PM
RamAir95TA's Avatar
I used a set of new stainless bolts to seal mine.
Old Jan 5, 2010 | 03:13 PM
robsquikz28's Avatar
I used the canton with a fel pro one piece gasket with NO leaks at all, 12k miles and no leaks at all anywhere from pan with the stock oil pan bolts.
Old Jan 5, 2010 | 03:25 PM
djjab57's Avatar
Im glad to see, there was a thread a while back where all most everyone was having major leaks with theres
