ac delete?
Old Jan 6, 2010 | 09:55 PM
speedracer2536's Avatar
Default ac delete?
is there a way to get rid of the ac/stuff in the lt1 and keep the heater?
Old Jan 6, 2010 | 10:00 PM
RamAir95TA's Avatar
The A/C and heating system share no components whatsoever, so yes. You need an A/C delete pulley and that's about it. Evaporator, lines, compressor, condenser, etc., can all come out while retaining the heat.
If you want, you can also remove the black box from the passenger side of the engine bay with a block-off plate (carried by a few site sponsors) and modify it slightly to still accept the heater core hoses. Remember you don't need to remove the box - just if you want the engine bay to look even cleaner.
Here's a good link:
https://ls1tech.com/forums/lt1-lt4-m...x-removal.html
Old Jan 6, 2010 | 10:02 PM
thats what i meant i wanna take that box out
Old Jan 6, 2010 | 10:03 PM
RamAir95TA's Avatar
That link should have everything you need to know. The dash does have to come out though - some guys don't like that part.
Old Jan 6, 2010 | 10:04 PM
btw i dont have an engine and tranny in the car.. could i just hack open the box without taking it out? is there a good write up out there?
Old Jan 6, 2010 | 10:55 PM
the_merv's Avatar
Veteran: Air Force
All kinds of good info in there..
Old Jan 7, 2010 | 01:29 AM
robsquikz28's Avatar
read the post in no. 2
Old Jan 7, 2010 | 05:55 AM
GIZMO's Avatar
Originally Posted by RamAir95TA
Cool. It's a shame that the factory didn't do it that way. My factory AC-delete Formula came with the same box as the AC cars, except it had a piece of board glued over the opening that the AC stuff normaly runs through.
