head gaskets
Old Jan 10, 2010 | 01:24 PM
bigbusa1's Avatar
Default head gaskets
hey i am building a 385 lt1 its going to be about 11.5-1 comp. it will be n/a and maybe a 100 shot later on. what head gasket would you recommend for that setup ? thanks
Old Jan 10, 2010 | 01:43 PM
RamAir95TA's Avatar
How do you know what the compression is going to be without knowing what head gasket you're using?
Head gasket choice depends on a few things, like quench, desired SCR/DCR, piston choice, combustion chamber volume, etc.
Old Jan 10, 2010 | 02:23 PM
bigbusa1's Avatar
the piston kit said 11.17-1 with 58 cc heads. i assume that would be with a stock thickness gasket the heads have been milled slightly and have bigger valves so i figure some where aroun 11.5 just a ball park i am looking for a good gasket for that set up thanks
Old Jan 10, 2010 | 02:27 PM
RamAir95TA's Avatar
Lots of assuming going on. You need to get some hard numbers.
Piston size (-5cc?)-
Bore?-
Stroke?-
Deck height?-
FWIW, I run an Impala head gasket at .028" with a zero-decked block and 53cc heads resulting in just under 13:1 static compression.
Have you consulted your engine builder yet?
Old Jan 13, 2010 | 05:53 PM
bigbusa1's Avatar
my question was more about brand. do people prefer fel-pro,mr gasket gm performance ect. im just looking for a quality gasket
Old Jan 13, 2010 | 06:13 PM
MattSapp95_T/A's Avatar
I use victor Reinz 5898 they are .26 and the same as Mr. Gaskets
Old Jan 14, 2010 | 02:46 PM
BLWNLT1_T/A's Avatar
I too am having trouble finding a head gasket. Dont want to get the block o-ringed but on the deck it says use .040 head gasket. Any suggestions?
62cc heads
-22 cc pistons
3.480 stroke..
Sorry for the hijack.
Old Jan 14, 2010 | 03:49 PM
djjab57's Avatar
My Engine builder and Head guy both told me the same thing Mr. Gasket 5716
Old Jan 14, 2010 | 04:02 PM
pillarpod's Avatar
^ +1 i've herd that Mr. Gasket is good stuff
Old Jan 14, 2010 | 08:00 PM
The Mr. Gasket ones are like $85 shipped through summit you can get the Victor Reinz through CNCmotorsports for like $45 shipped and they are the same gasket...
Matt
