A/C Firewall Delete
Old Jan 14, 2010 | 12:40 AM
Meen95z's Avatar
Default A/C Firewall Delete
Im recently started my a/c delete project and kept the heater.. Here is what it looks like so far.. Thanks to The Merv for some info!! But have to get the interior back in still and try it out.. Also removed the passenger air bag and bracket while I was at it..
Old Jan 14, 2010 | 12:51 AM
suicidal racing's Avatar
nice..im waiting on my headers ac delete pulley setup to come in this week to do mine..im doing the same setup for right now till winter is over..your came out real good.
Old Feb 18, 2010 | 12:56 AM
z28charged's Avatar
so you can keep your heater core still that's great.how do you get the compressor out it's being stubborn
Old Feb 18, 2010 | 07:34 AM
ThreeHonks's Avatar
So I assume that you just cut out the a/c box from inside the engine bay?
Old Feb 18, 2010 | 07:48 AM
the_merv's Avatar
Veteran: Air Force
I just cut the face of it off flush, and made the Panel.
Old Feb 18, 2010 | 08:08 AM
ThreeHonks's Avatar
I got a template from a member on here in 1/8" thick aluminum, so im good to go there. What was your technique for cutting it out? die grinder, roto zip? anything to watch out for when cutting?
Old Feb 18, 2010 | 08:27 AM
the_merv's Avatar
Veteran: Air Force
Dremel worked fine..just took a few minutes. Just get in there and cut pretty much.
Eventually I'm going to re-design the Heater Box though..I don't have the flow like I used to..I have alot of holes that the Blower Motor blows air through..you will see what I mean when you get in there and start cuttin into it.
Old Feb 18, 2010 | 09:09 AM
ThreeHonks's Avatar
lol so basically dont be scared, just take a dremel and go to town?
Old Feb 18, 2010 | 09:33 AM
outkast6991's Avatar
this is kinda scary because i was using your old post as my guidance. what would you have done differently? i have the inside of the box cut already for the air passage and the plate made up. all i have left is to cover the hole in the box with tin and bolt on the plate. any info would be great, i really don't want to do this twice
Old Feb 18, 2010 | 10:38 AM
the_merv's Avatar
Veteran: Air Force
The part with the Hole that I covered up with the Tin..mine has alot of gaps..I may fiberglass it and make it air-tight all the way to the Heater Core. It will definately help.
Old Feb 18, 2010 | 02:21 PM
thanks man i'll give it a shot this weekend. i'll grab some pics when i'm done
Old Feb 25, 2010 | 12:26 AM
Meen95z's Avatar
I actually took the dash out and took the heater and all out, cut it outside the car and put it back in.. Not saying it was the easiest way to go, but I wanted to ditch the airbags and stuff while the dash was out anyways..
Old Feb 25, 2010 | 08:27 AM
YSILT1's Avatar
Here is a pic on how I did mine. I flushed the box to the firewall. Then made a sheet metal panel with a opening in it to allow airflow to cross from one side to the other.
It was attached with urethane seam sealer and sheet metal screws. No air leaks.
Sorry for the bad pic.
Old Feb 25, 2010 | 11:09 AM
djjab57's Avatar
Us guys in the deep south cant do with out the A/C so thats no good for us LOL. Its not much fun driving around in the 100 degree days even with the T-Tops off especially with the humidity
Old Feb 25, 2010 | 11:41 AM
the_merv's Avatar
Veteran: Air Force
That looks damn good.. how does the Heat work..still blow strong?
Old Feb 25, 2010 | 08:02 PM
earl lee's Avatar
Not true, I live in atlanta and havent had ac since Ive owned this car (4 years) and ive been fine.
Old Feb 25, 2010 | 08:03 PM
93v8clone's Avatar
so we can pull the a/c panel and keep the heat ? how so im not really smart and need lots of pics lololololol
Old Feb 25, 2010 | 08:10 PM
MattSapp95_T/A's Avatar
Jigsaw works great with a fine tooth metal blades....then use a file to clean anything you need to.
here is a ok shot of mine
Glad you finally got it!
Matt
Old Feb 26, 2010 | 12:44 PM
YSILT1's Avatar
It blows the same as it did stock. I did it this way since I just didn't feel like pulling the dash.
Old Feb 26, 2010 | 02:16 PM
Ralls's Avatar
It's been so long since I did this. I remember a wire (not the vacuum line) that went to the A/C Evaporator. I think it was a temperature sensor. What did you guys do with it?
