ls7 lifter ?
Old Jan 19, 2010 | 02:51 PM
TravisMcGill2000's Avatar
Default ls7 lifter ?
Should i soak these lifters in oil before i put them in. If so for how long. Thanks travis
Old Jan 19, 2010 | 03:07 PM
the_merv's Avatar
Veteran: Air Force
I usually soak them for a week or so.. but that's just me. Overnite should be fine.
Old Jan 19, 2010 | 03:16 PM
k thanks
Old Jan 19, 2010 | 04:34 PM
speedracer2536's Avatar
in my last build i soaked them for 4 hrs and that was about it.. ran my motor hard with a cc306 for 10k miles reving to 6500.. but the longer the better i just didnt have the luxury at the time
Old Jan 19, 2010 | 04:38 PM
Elliott's94Z's Avatar
Yes you should and over night would be more then fine
Old Jan 19, 2010 | 04:39 PM
ThreeHonks's Avatar
a couple hours and they will be fine.
I cleaned mine with thinner and then dryed them with compressed air. I only soaked mine in oil for about 30 min and it runs totally fine.
EDIT: one of my crazy LS buddies put his in dry and it still ran fine
Old Jan 19, 2010 | 05:00 PM
fergymoto's Avatar
It is totally unnecessary to soak them for more than 10 minutes or so. Even that is longer than needed. You are only soaking them to get more oil than what is there from the factory into the rollers. LOL @ soaking them for a weeek
Old Jan 19, 2010 | 05:02 PM
RamAir95TA's Avatar
They are pre-filled with oil from the factory. Just clean them off with thinner and call it a day.
Old Jan 19, 2010 | 05:19 PM
djjab57's Avatar
Merv has OCD man ease up on him LOL
Old Jan 19, 2010 | 10:05 PM
shbox's Avatar
They need to be cleaned with a solvent and then oiled. You want to get that sticky manufacuring oil off of them.
Old Jan 19, 2010 | 10:26 PM
fergymoto's Avatar
I guess so lol
Old Jan 19, 2010 | 10:46 PM
robsquikz28's Avatar
Bingo then oil and install them in that order!!
Old Jan 19, 2010 | 10:51 PM
the_merv's Avatar
Veteran: Air Force
Hey you *******..lol
I got them about a week before I built the Engine so I stuck them in a Tupperware, poured some Castrol 10-30 in there and let them sit till I used them.
Never knew about having to use Solvent..I guess soaking them for a week took care of it..
