lt1 water pump
Old Jan 23, 2010 | 08:25 PM
fuel's Avatar
Default lt1 water pump
what is the pipe on the bottom right side.....the hose goes to the bottom of the radiator. do you need that hose or can it be disconnect.
Old Jan 23, 2010 | 08:35 PM
RamAir95TA's Avatar
That's the oil cooler bypass. It can be disconnected and blocked.
Old Jan 23, 2010 | 08:40 PM
fuel's Avatar
i have my oil coller disconnect......what is the hose that goes to the driver side bottom of the radiator
Old Jan 23, 2010 | 08:45 PM
airfix's Avatar
If it comes out of that Port on the wp and goes to the bottom of the rad. It's the oil cooler bypass hose, It can be blocked. Just as Ramair stated above.
Old Jan 23, 2010 | 08:49 PM
fuel's Avatar
can i get rid of that hose and cap of the pump......or is that port importent on the pump or the radiator
Old Jan 23, 2010 | 08:52 PM
RamAir95TA's Avatar
Two people have told you to JUST BLOCK IT AND REMOVE.
Old Jan 23, 2010 | 08:56 PM
Gojira94's Avatar
You can cap the radiator holes with a pair of bolts- new ones come with plugs in them in case you don't have the cooler...
Old Jan 23, 2010 | 09:00 PM
fuel's Avatar
im going to a small race radiator and im only wanting to use the 2 big hoses for in and out.
Old Jan 23, 2010 | 09:05 PM
airfix's Avatar
So cap the water pump and be done.
Old Jan 23, 2010 | 09:06 PM
fuel's Avatar
thanks guys............
