Stroker kit 383...
Her are a few numbers I remember . This was a budget Daily Driver build with a 383.
Virgin 2bolt block (I got a few)
ARP main bolt kit (was laying around)
Eagle Balanced rotating with Hyper. flat tops. Around a Grand new with bearings and rings
Machine work $1600 or so. Trued the block, Decked it, main lined, Bore and hone with plates. Short Block assembled.
I let a Local guy do the heads (to Try) for $1,500 with Valves. I supplied the springs. I got a set sitting here to go to Lloyd when the time comes.
I had Cam Motion cut a 228/232 111 cam for it.
I went with Jegs(made by Lunati) Rockers and spent the time lining them up on the valves correctly with Isky Adjustable guide plate. VERY quiet valve train even with the cheap $100 e-bay lifters I used!
Smith Bro's got the call on the custom Push rods. I also spent the time on Correct valve train Geometery!
Cleaned up the intake and the stock injectors
LT4 Extreme timing set(loud)
Pro Products balancer and B&M Flex plate ZERO balanced.
SLP headers.
Stock Throttle body and MAF with MOROSO CAI
We spent a whopping 30min or so dialing the tune in and have been beating it since
Rolling burnouts over 200ft long and 12.4's every pass.
She has a mild 2,400 converter and stock 3.23 gears and 275 17in drag radials.
I am going to race it in the local brackets this year so we are going to put it on a dyno and finish the tune. She is very mellow with only 30 degree's of advance and slightly rich
All told I have a have a $6,000 figure floating in my head for total cost on this budget build for EVERY thing I spent over what I had laying around.
If you have a $2,000 budget Call Lloyd and just do heads. Other wise $2,000 is just a start on a good build.
Enjoy!
I'm just trying to be realistic here. I never said you can't get a rotating assembly for under $2k, you just can't do the entire build for $2k. Like 99blancoSS just said, you can get the rotating assembly and cam for $2200. BUT like I said, you still need rockers ($300), springs and hardware ($200), possibly lifters ($130), head gaskets ($80), new timing chain/sprockets ($100), miscellaneous ($100), and a new PCM tune on top of all of that if you want it to run at all ($150). These are just ballpark prices to do it RIGHT. I am an advocate for doing things the RIGHT way, and if that means spending more money, so be it.
You do the math. I'm not trying to discourage you, just make you aware.
this is getting good
